The jap (boss) way of fitting catchcan setup to RB20's. Two catchcans like a boss. (what does the jap say?)
1st catchcan separates oil from blowby gas and drains oil to sump via a drain under 1st catchtank (green line in above photo). The 2nd catchcan catches left over oil (if any) and clean blowby gas (no oil) gets sucked back into intake pipe infront of turbo from 2nd catch tank.
That person with dual catchtank setup on his RB20DET always had a problem with a single catchcan filling with oil and had to pit every 2x laps. The addition of 1st catch tank was the solution, where oil drains back to sump and engine doesn't lose oil. Loss of oil in sump could could have resulted in oil starvation, engine failure. Also he doesn't have to pit every 2x laps.
Catchtank size is important due to blowby gas slowing down enough, so oil can be separated. Catch tank size is based off capacity of engine (amount of blowby gas), so catchtank varies in size from a RB20 to RB30 engine.
You'll see a dual catch tank setup on Mines R34GTR. Now you understand why it has 2x catchtanks and why the catchtanks are a certain size. Mines go one step further by fitting baffle plates to cam covers to separate oil from blowby gas before it exits camcovers.
Mines have copied others that having been doing the 2x catchtank setup since the 80's on Group-A RB20DET racecars, Group-A R32 GTRS, etc, but modified it slightly
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
