I've got a meeting with my supervisor for a research essay i'm doing.. he emailed me yesterday saying he was available 'tommorow'.. off to a good start haha
Spoiler: that's not how you spell tomorrow
Yeah, big whoop wanna fight about it?
even still if u want to rent it out
why bother if you are just going to rent it out
buy a shitter in a place like craigeburn or something and rent that out
and rent where you want to live if you insist on living in st kilda / elwood
charge more rent for inner city joints...
True. Elwood fetches a decent price rent wise.
im not convinced good rent money = good investment idea, as with good rent comes good (ie high) repayments for the land value
i would expect the good idea behind investment would be good growth
thats why i reckon its better to buy a renter in some suburb thats cheap and likely to go up
plus its easier to afford and the land is less value
just see no purpose behind buying in stkilda/elwood ?
unless you can afford it and you have tons of spare cash
In 5-10yrs time, a property in inner city will increase more in value than your average suburbian household (this can be argued, depending if you pick an unusual growing suburb)
For example; Bendigo have plans for a new hospital, so property prices will increase due to more demand for housing for nurses, doctors etc
Gladstone (in qld) is planning to setup a major oil/gas refinery and again demands will go up.
However, a steady rapid incease in property value is always certain for inner city housing. (unless australia suffers through a gfc scenario, but then every house will be affected) and I believe you will get larger growth in the inner city than your average suburbian location in a short period of time
Huge rental demand in St.Kilda and Elwood. Stats reveal 70% of residents in both suburbs. Meaning much higher rent (due to demand)
A 1 bedroom appartment can fetch as much rent as a 3 bedroom house in the suburbs.
Alex, share your wisdom on the housing industry :P
Guest
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
