I've never been the biggest fan of red. Black is more my style :) A nice shiny black.
Man... I'm getting wood just over that description!!
Hmm... Flared guards... How would that look on mine? I'm going for a similar bodykit to last time but more aggressive rear bar and alternate front.
Get some decent wheels to go with the black.
Silver / Bronze or Black with a Red lip... That's how I like my Black coloured cars
I like chrome lip wheels. Centre can be silver/black/gunmetal, I don't mind.
I want something like TE37s but it's hard finding good offset in an MR2.
7.5 in front and 8.5 rear with +29 offset on both would be exactly flush.
Is this the kind of look you like???
Edited by jezza boii
Fucking love that look!
WORK Meister S1's or SSR Professor S1's, both look great!
On that note, both those wheels look the same. :)
Cuz of the polish lip, you can mix up the colours a bit to get some variety happening.
Any of those center colours would look sic!
The Time Attack TE37's would looks nice, but good luck finding those. Hah!
those wheels will probably cost more than the price of your car :) at least that's what I found with my golf and work meisters.
Yeah, I won't be getting Meisters. I only want to spend about $3000 max on wheels + tires.
So what do you think of the overall look of that car Shan? Coz that's my inspiration for this project.
But unfortunately I won't be pulling 330rwkw like him :( Otherwise I could buy in on this "my dick is bigger than yours" contest between Kris and Hamish :P
grow some
ahahahahah
nah i dont wana mess to much with what mitsubishi already made good
i have seen the 1/4s being wrecked because its flared out, evos in US that have had them done
ill roll the lips though
just pump the whole guard then.... i got nearly 2 inches on my 33 like that :)
(but get athid to do it....)
and no I dont care if kris has more power than me... i actually hope he gets it as he NEEDS it to get away with the paint :(
yeh thats what i mean pumping or flaring its gona look shit on the evo
lipping the 1/4s is all you can really do cause the 1/4s look good as they are
I've never been the biggest fan of red. Black is more my style :( A nice shiny black.
:) okayyy...
haha if it stays too long in one spot it'll cause permanent retinal damage. with 300kw, it'll only be temporary
2x Adjustable Cam gears - $129 from Access Auto
Water pump, timing belt, bearings, seals, fuel filter, thermostat, stud/bolts - from Kudos Motorsports
ASI 52mm dual alumn radiator - $200
Need moar money
Then comes other crap to get water/meth working and then re-tune :)
Guest
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
