Because he got a radiator that was too big and has to piss off the best cooling - the clutch fan :P
$600 in the red FTL
shhh. he's building a track/street car. :D
y'all nga's just lack foresight.
:D
in other news, got caught in that massive downpour before... absolutley soaked :)
least i got the rest of the day off
And you need all this why? Lol
dunno bored i guess
Because he got a radiator that was too big and has to piss off the best cooling - the clutch fan :D
$600 in the red FTL
proper shrouded thermo fans > engine fan
shhh. he's building a track/street car. :(
if they are, thats good
was hoping they were std globe and not some uber spec light assembly in one piece
will check it out when i care and can be bothered
dont drive my car to work so not urgent urgent
white ones or yellow ones? or regardless of colour?
All foglights are illegal regardless of colour, pretty lame. Unless they turn on with the headlights then they are legal, but if there is a separate switch then they are classified as foglights
the 32 and the evo both had the foggies in the headlights (both use a switch for them, 32 was the sedan h4 n1 style light)
how does that work then when they came from factory like that but dont turn on when you headlights go on?
I have a button on top of the dash. Near the rear window demister for the foglights
the foglight button would turn on the foggies and the parkers, but i think law means that when you switch to headlights the foglights will then turn on. Some crappy outdated law. I wonder if there is a law for the white LED strips under all the headlights
some confusion between fog and driving lights here
Using fog lights
Front fog lights are designed to better illuminate the road in fog, snowfall, rainstorms or dust clouds. They can be recognised by the narrow pattern of light emitted.
Road Rule 217 states that drivers must not use front or rear fog lights unless driving in fog or other hazardous weather conditions that cause reduced visibility.
Fog lights cannot be accidentally switched on. They must be switched on separate from the main and dipped beam head lights.
Using driving lights
Driving lights are designed to illuminate the road over a long distance. They are the same as the high beam (main beam) head light and emit the same lighting pattern.
Road Rule 218 states that drivers must not use the high-beam headlights when driving:
* less than 200 metres behind a vehicle travelling in the same direction
* less than 200 metres from an oncoming vehicle.
Driving lights cannot be accidentally switched on. They can only be switched on and off with the high beam head lights.
Guest
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
