you are worse than a fkn woman
look when i'm sitting butt nekid on my leather seats, I wanna make sure the colour goes with the new paint.
altho... most probably i'll just leave it cream and deal with it.
go brown. you'll leave skidmarks if its a light colour and you are nekkid
it's a 2L SOHC FWD golf. sif it'll make me produce skidmarks... well unless I do an epic understeer while trying to corner in the wet. In which case on account of it being wet I won't be nekkid, so no probs there either.
Lol shan if you put wider rims on the back on a fwd then you are a massive poser lol
lol cos I'm gonna need massive amounts of traction to put all 80kw down. it's for stance and fitment... and that's all it's for.
get the fuck out mr stock suspension for superior acceleration.
good to see you've thought it thru
its a hardparker. was never gonna be anything more. posing is the whole point
says the guy with the fluro orange car..
lol
Guest
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
