make sure you upgrade your pivot bolt, fork and the right size throwout if you're getting heavier button clutches.
chucked my OS Giken triple in and after one track day couldn't put it in gear. turned out the factory fork and pivot had warped/snapped. another guy who came to the workshop used the factory throwout and fucked his clutch up after one track day.
haha costed me $220 all up with rims
his sending them to a depot in LA where ive got a mate that brings in his stuff from there
and my mate not charging me to ship it here :down:
Sweeeet - have you figured out how wide your flares need to be?
nah not yet, unsure on the exact offset of them yet.... would be massive neg thats for sure lol
once they get it ill test them up on car and measure it all up and go from there
reckon itll beed about 3inch flares though, cause i think the rims are about 8"
tl;dr
summary?
Integra driver failing to understand that venting hot air out of the engine bay is beneficial.
I have another screen shot at home of him telling people that getting water in your pod filter will cause you to blow a tie rod.
Brings the lolz.
who can weld stuff for me? small job, need to chop off a bit of exhaust and weld on a flange and a bit of straight pipe.
anyone? plzzzzz, wanna have car ready for Buller cruise
mmm i can weld, but wether i cbf lol
cefiiiiiiiiilo! with S14A front conversion. and R33 GTR style front bumper. think it's in thailand or malaysia.
Fuck, you know everything!
LOL!
It was in the Internet Movie Cars Database (IMCDB) listed as unknown and no one can tell what it is...
I dunno if i can trust 'you people' haha..
Do you have the equipment? I pay cash ;)
'you people' mayteeee comon..... dont be lyk dis, you knw we gud at wat we do brutha
you pay kesh? thats all dat matters mayteeeee
yeah dunno how much mig gas i got should be fine though.... aslong as the pipes arnt stainless i can do it, dont have a tig
oh if it's in a movie, then it'll be malaysia for sure. they made a couple of drift movies in F&F style. one of the baddies drive a cefiro with some work done to it.
actually. hold that thought. A pillar gauges on the left. must be LHD, which means it's in the phillipines.
Guest
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
