I'd take that merc over anything and everything. Pulled up next to one at the lights some months ago, b
Tuffest thing ive ever seen. So fkn phat and the sound :O
How bout the pearl white 430 scuderia with the black wheels?
indeed, ugly.
the f**k....
pro fb post, brought many a lol
493kw mang.. and they look even more mental irl
Sif buy a 300k Maserati over that thing
meh dont rate it that much for $530k
you sure if there is only 9 in the country what are teh odds of pulling up next to one?
No probs brah... Just had some knob juggler work shop try rip me for a new one because it's "detectable" for those wondering what I'm on about, I like to drive with my penis hanging out the window.
made a video for lulz with Ita Buttrose
made the ABC news and the Age/Fairfax homepage... apparently it casts her in a bad light. you know, cos cheesy rap to plug a book is srs bzns.
Guest
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
