i said MAYBE fool (maybe means almost definately not, but there is a 1% chance)
no shit lol
jizzy come entertain us
btw- wasteland flames are really not that bad... even though i cry myself to sleep every night.. really not that bad.
anyone up my way today? need some help with something
Edited by Mohsen
Ey knob shiner I might come to this fishing thingo if I can get my parents' car. What time you expect to be back home?
im coming in my mums car too lol. fits everything
pretty much pack up when the fish stop biting. last time we went maccas or the lebo bakery on high street for brekky.. soo really up to you if you wanna leave etc
if its a nice day you see all the hotties walking around the beach etc going for jogs
who knows how to create website/register domain manage website etc etc?
i need to make a website and set it up so i can run it (fairly shit with computers) so must be simple, and what kind of budget should i allow for this?
kgo.
oh and good luck leigh :)
registering and getting the space is easy
i did mine for 120 a year on a budget hosting provider, thats for 2 years with domain name registration
paulr33.com is hosted by them and it works fine, fairly quick, reasonable set of features etc
the hosting company is juston.com
building the site isnt too hard
there are a fair few programs out there to do most of the work for you
just google some good ones then download it via torrent
Hmm my parents will probably need the car after ~11 so...
Guest
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
