hey guys just looking at a few cams for the RB20... iv seen Tomei mostly and they are around the $1000 mark but CAMTECH CAMS make them for a bit cheaper.
Wondering what you guys think on putting a bigger cam on a lightly modifed motor?? Will i see many gains??? Im not to good on cams lol
Any help will be appreciated
Not on a mild rb20.
Power gains? Nope.
All you will do is shift the power band, and that is only going upwards most likely... so not doing a street RB20 any favours unfortunately :)
Pretty sure Troy tried some Tomei cams - He went back to factory cams if memory serves me correct
Check the RB20/260rwkw thread, it should have the details in there either way in far more detail :huh:
unless you want to push 300hp+ i would be upgrading other area's of external bolt on's and having spent a fortune on a RB20 i would
advise anyone, the money is better spent on a 25 conversion or 25/26/30 combo. The money it cost me to get over 400rwhp
could of got me over 500rwhp in a RB25 and a more usable power band, but in saying that i still like the little 20.
Cams on std engines with little turbos with small A/R hotsides dont seem to like cams. Now a built RB20 with a big 0.86 A/R 500hp turbo....cams may help....nobody can reliably tell me which is making me nervous about building up an RB20, nobody can give you a tried and proven recipe :blush:
Cams on std engines with little turbos with small A/R hotsides dont seem to like cams. Now a built RB20 with a big 0.86 A/R 500hp turbo....cams may help....nobody can reliably tell me which is making me nervous about building up an RB20, nobody can give you a tried and proven recipe :bunny:
roy i got 321hp = 240 rwkw outta rb20 with 264 in / ex cams and hks 2530 0.63 at 19 /20 psi
would you not agree most rb20 with just straight 2530 + 20 psi = 230 rwkw? if so then approx 10 rwkw gain ?? ( I know very very simple comparison and every dyno is diff etc)
Not saying this is what id do on a mild engine as bang for ur buck is not really there
same cams i think make big diff with the rb22 on 2835 use more of the rev range where the rb20's love to be
Things is i made 260rwkws with std cams, installed 260/8.8mm cams and lost response and 10rwkws, even with tweaking the cam gears and tune for about 75 dyno pulls. Could not get it back, too much bak pressure from the tiny 8cm housing i run
260-280rwkw 1.2-1.4bar standard rb20 here. The 280 was with a boost leak too :bunny:
same turbo as Roy's but different plenum.
I'm thinking about giving Status' cams a go when I have the time. But I wouldn't think you need cams till about this power level.
Correct me if im wrong but any mild or more serious cams on an rb20 is only going to shift the curve and fatten it up while it is there. But it wont do a whole lot for low down.
didnt you make that power with 2530 on ALLSTAR hubber, its known to read 5-7% higher which would be around 20hp... Which would mean around 300rwhp on roller which is pretty much dead on normal
Edited by Cerbera
yeop yeop ... cool was just trying to give some comparison coz no one seems to run cams in their 20's
as said im in agreeance, doing it again i wouldnt bother, spend the extra $$ on other performance mods
Yeh i know two people in Melb with 2530s and Poncams and they dont feel that different to an RB20 with a 2530. Sound better but thats about it :banana:
I cant remember the settings other then retard the hell out of the exchaust cam (from memory about 4 deg)
What about Poncams with cam gears? Is it possible to get, to a degree, stock like response with the benefits of aftermarket cams?
What benefit? The two 2503 powered RB20s with Poncams drive like a RB20 with std cams. There isnt a tangible improvement in my eyes. Could be wrong though. They both make power where you expect, they both make about 220odd rwkws. They both have boost drop off at high revs. I think it comes down to the fact that eveb though the engine is happy enough to breath with std or aftermarket cams, with the lil 2530 and other 320-350hp turbos they simply have too mcuh back pressure in the exhaust housings and choke the engine up.
I had a friend with an R33 with Greddy plenum, HKS cams and a 2530. It made 230rwkws and came on like there was no tomorrow. but i dont think the cams did anything for it either until he got the 3040, T66 and other setups on it
yeah im fairly sure it's just +2 inlet -4 exhaust, just need someone to confirm
to be honest even with a gt2530 cam gears are a waste, the inlet does near nothing and the exhaust frees up a bit with a bit of retard but again minimal. The rear housing is the restrictrion not the head (cams etc)
refer Roys post it is bang on
Thats why i am going back to the 10cm housing, Plazmaman plenum...will see if cams work for it then. Need to beat that R31 fella making more power then me :)
Come on Trent, give me the specs of something you have seen work. :) I am torn between installing my solid lifters with some 260/10.25mm cams to go with the 10cm housing and 2.4L bottom end or just keep my money in my pocket and keep reving the crap out of the lil std motor and see how it goes. I am so hot and cold about all this :( Its safer to go with a known RB26 or RB30 setup, but.... :)
As if im going to use a pissy little 2530 :)
I've got a ATR28G3 with 0.63 rear... Same turbo as you tuned for Stao a while ago and made 500nm of torque, so my question still stands :)
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
