4th gear stopping before limiter. I have alot of mechanical sympathy :)
Limiter is 8k. I like my stock rod bolts non stretched :D
Hmm. Something is up. 4th at 8000 RPM is 235 km/h and you're going to 190 ish km/h which is 6400 RPM. :S
Could the road speed on the dyno be wrong or something?
It's only my gay 4door gtt that needed so much fuel system work
But hey Can't complain with 367 @the wheels
At least your gay gtt runs ya kent :P stupid flex fuel!!
Nice result so far! Though to be fair I'm not sure if the PT6262 will really be showing its mettle yet, have you had any stock RB26 with a GT3582R on E85 on that dyno? That would make for a very interesting comparison
No i havent. This is the first single on rb26 on this dyno.
I wish i had a forged motor so i could run 35psi. I think it be close to 500kw
took it for a cruise to get some pizza. Without finishing the tune down low it drives very nicely. Below 3 very little boost. Above it picks up nicely.
So are the Precision turbos their own CHRAs or common with Garret. I am looking at either a FP73HTA with one of these housings but also considering a Precision turbo...but makes life easier it i can run one of these rear housings
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=TP&Product_Code=ATP-HSG-075&Category_Code=
Has anyone worked out the rpm vs speed yet..?
How fun would that turbo be on a 3lt
PT6266 would be more fun :D There are quite a lot of Supras running them, they seem like a pretty brutal all around setup.
Off topic, Jez u get the pic etc? I have the same issue as Kurtis :(
Hey buddy, yes i got the pic. Very dissapointing i was sort of hoping it was an odd issue with Kurtis's car, but if its happened on a different car with another workshops setup makes it very annoying. Hopefuly warranty wont be an issue.
Txt sent
How does the turbo sound when your up it Jez?
I've been told they are rather quiet compared to most singles...
On the dyno from in the car with headphones on i couldnt really tell. U can definately hear it spool up like a jet when inside the car but i havent been incar with a similar setup so cant compare.
No prob Jez , just put it onto mine and see what it will make :)
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
