A little? lol... A LOT!
I just wish I new where to start, it's got everything it needs to make a decent number, but it's knock restricted.
When jez tuned it last the exhuast was way to small, now that I've got a bigger system coming from jap and I made some 3inch tuned length front pipes into a 4inch merge. The exhuast issues should b over, so it's back to jezza's shop to c if there's any gains.
Strange thing is, I had a 4inch system made, and we chucked it on the dyno, only got 7kw gain with adding timing and boost.
C what happens, maybe we need to play with the cams, or something.
Depends what manifold you get.. The Full race one I have was designed for fitment on 33/34s. Tried putting it on my 32 and the compressor fouled on it..apparently full race have rectified this for 32s now
A/C didn't work anyway so I'm not too fussed, then again I may have wanted to fix it one day :s
I saw a dyno graph from a famous 32 on the weekend. It's now running a Precision single (6766 I think he said). The Precision shits allover the -5's for response on the graph, and from his times, on the track too! The 32 is still 2.6 as well so these turbos are obviously a good thing!
Correct! and yes WOW! it has me thinking the EFR's are on their last chance... :yes:
I've already emailed him to find out exactly what version he has on the 32.
The 34 is running one also, however he likes the one on the 32 better.
One thing he did say to me was to buy bigger than I think I'll need and I won't be disappointed, they are that good.
I would choose a Precision over an EFR any day. . .too much hype with the BW's. . .too many results to look away from Precision. . .sorry, but a 2-year wait on an EFR is ridiculous. . .
bri73y.. .do you have a chart for that r32 running the 6766? I'm running this on my FD. . .sounds too good to be true that it would shit on the -5's. . .
No sorry, it's not my car, although it has lived in my garage for a while previously. Damn should've stolen bits off it when I had a chance.... :whistling:
Any email back? The one on the 34 did look a little bigger but by how much I couldn't say. I'd love to know!
What do you think you will order for your car John? 6466?
Hey Joe, or anyone for that matter..
Is there any evidence that the Full Race Manifold is worth the cost vs 6boost & ETM etc being about double the $ ??
Will wait and see how Piggaz's turns out, as I also have a 2.8, been running a TO4Z for a couple of years on stainless china manifold, time to get with the times, with a good manifold and probably a Precision..
wouldn't the one Jez is running, with 30+ psi on a 2.8L with cams etc see 450-500rwkw ? with awesome responce .
Edited by tricstar
Is there any evidence that the Full Manifold is worth the cost vs 6boost & ETM etc being about double the $ ??
Will wait and see how Piggaz's turns out, as I also have a 2.8, been running a TO4Z for a couple of years on stainless china manifold, time to get with the times, with a 6boost and unplumbing the gate.
Fixed, no need for new turbo :)
Well it made 436 on a 2.3 SR with 24-25 lbs of boost on the same dyno as i made 425 with -5's. It beat my setup low end and pipped me up top. I'd love to see what it would make with 30 psi!
If the 6466 is too big just rip it off and drop back 1 size. Little touch up and away we go!
Honestly mate don't know if the full race is better or not. Would need to do some back to back testing which would be a real pain in the ass as you would need to plumb up 2 different sets of gates.
If I had my time again I would probably just bought a 6 boost one for reasons such as
1. Cheaper
2. Quicker to obtain (each fullrace manifold is made On order)
3. If it cracked or failed in anyway would be easier for warranty
4. The full race is a bit of a nightmare plumbing wise.
Though I do like how the manifold looks and how it makes the turbo sit towards the front of the car.
I also had to cut a bit of the re enforcement out of my bonnet to fit the Massive frame of the BW
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
