That's quite a big difference in response for 40rwhp! :O
When you are running 205's and trying to compare the difference between 560hp and 600hp your kidding yourself.
I will often tune a big hp xr6t (over 10000N of tractive effort) - only to go back in power over multiple runs. Does it mean the engine is making less hp - no just means the tyres are absorbing the hp and not transmitting the power to the roller. If you drive he car on the road and scrub the rippled edge off the tread allow them to cool and then throw it back on the dyno the hp comes back up. On a 500rwkw car (11000N of tractive effort) I can see another 50rwkw when the tyres cool down and loose there edge.
Sounds like what happen in that thread.
Yes, I expected it to be at the seller's LA based workshop in 2-3 days from Precision which is US based as well. Then hes goin to give it a once over and ship it to me, that should take not more than 2 wks generally. But he still aint got it yet.. :(
Oops this was in reply to Nismoids post
Edited by rondofj
So you send them the order...
They take effectively 24hrs to order it with Precision given timezone differences
Precision don't action it till the next day...
Apparently they need to assemble (read: bolt on 2 housings)... So that takes them a couple days hehe.
I can see how there could be a 4-5 business day delay here pretty easily dude and whoever you ordered it from wouldn't have it. Just relax... It took you 400 years to decide, let them take a couple days to sort it out :)
If they get it Thurs and ship it Thurs, it'll be here early next week which is pretty much smack on 10 business days (or so).
Who was the seller and how much did you pay/which pt turbo? I wonder if they can deliver this to your office lol..
I went through my tuner (Unigroup).
It's a 6466 CEA 0.81 twin scroll. The order was for 7 turbos all up so we got a little discount. I'm sure they will have no issue ordering one in for you.
The 6466 TS is going on a 2.8? This should be very very interesting, quite keen to see how this comes out - got potential to be huge fun :)
That's the one. Hopefully crack 500 on sub 25 pound... Then turn the wick up. Will have to wait, the 5's are going on first :/.
Somebody really needs to put something like a 6466 on a barra.. SOMEBODY
What - why?? PT6766 would be the smallest I'd put on one of those, there is someone running around with an FP GT3794HTA on one and it sounds awesome. They just need to wind up the boost and supporting mods a bit to justify it more.
Very nice, on E85 I assume? Why bother with the -5s? :(
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
