If you looking for a 3076R equivalent then go the 0.63/ 5558 which is what I did from research and Unigroup's advice, if you looking for bigger, then consider the 6XXX series...
I spent a heap of time comparing numbers on this also.
For memory when I looked at this (I dont have the numbers on me) the 6262/6266 are pretty much similar to a GT3540 and the Precision 6466 is somewhere between a GT3540 and a TO4Z# .
Obviously how these would drive will also vary based on the rear housing size/ split pulse or not etc.
All the T3/T4 ones are, AFAIK.
If you got one of their garret copy items it would have a water cooled core (IE the T28/GT30 variant stuff).
I always assumed bb chra had oil and water cooling.
I guess no one has had many issues with it though.
What did you guys do with the water lines? Just link the feed to the return with a braided line or something?
Tune all done, ran out of pump (fuel) top end so we stopped there but I'm fairly happy with how it went... May chuck another pump in and see how it goes but I'm happy for now :)
PTE 6262 on stock bottom end RB26 with a Greddy 1.2mm head gasket and Greddy drop in cams
Edited by SimonR32
Wow why u making so much power man- 450ish rwkw is it?? How much boost and no E85?
600hp at wheels? Very nice result gotta be extremely happy with that !!
Is that on caltex eflex ?
Sucrogen, we don't get E85 on pump over here :(
About 450kw at the hubs yeah, boost is on the graph 1.6bar to beef up the mid range and 1.4 bar top end. It's running E85
Awesome results mate. Hurry up and go to the drags :)
I considered cams :)
Hows it feel on the road?
Maybe, depends if I can be stuffed. Cams should make a bit more power, if you do cams I'll do another pump :)
Only drove it about it 200m, gave it stick in 1st and 2nd, held on... Was good!
What rear housing is on the 6262?
T4 0.84 divided
Very nice power! Looks a bit laggier than a Gt3582r, which isn't really that bad news on a turbo that will make as much power as this if you tried pushing it :-)
We overlayed a few GT3582R graphs and they were similar response. Remember hub dyno makes things look lazier than a roller graph and the run was only started at 3000rpm so not much time to wind up the big girl. Could make big power with another pump though, would go close to 700 if we were crazy haha
The boost isn't falling over top end either, it's just we layed more boost into the mid range to beef up the torque. If we had held that boost through it would have run out of fuel (and probably make another 30-40hp)
sorry if ive missed it, wondering if that a stock bottem end?
Yeah it's pretty clear it has plenty more flow in it - no question of that, for the lag it'll make way more than a GT3582R. I am most familiar with hub dynos, and the .82a/r T3 single scroll GT3582Rs tend to be all on by around 4300-4500rpm so barely any more lag considering the extra power but I'd have guessed it to be noticeable.
Compared with the T88 it's noticeable haha
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
