Good ? on comp Ratio as it hasnt been tested since the built to be honest it has sat in the shed for 3 years with doing nothing. It comes out sometimes & getz fair up it down this road I know quite well. Head work ported Polished supertech vavles. It made 450KW with the HKS To4Z strapped to the side of it with race Fuel 23psi.
Twin scroll ryan 4inch inlet & 3inch out from memory. Has 3.5 inch exhaust but not that thats going to matter its coming straight out of gate so should sound the goods lol.
Cool can't wait to see your results trying to decide whether the 6766 is going to be too small for my new 3.2L thats in the build ATM ;)
1000 flywheel hp or as close as I can't get with good spool
What fuel? If on E85 then the Precision PT6466 seems to be the man for shooting in that area - basically every result I've seen for that turbo have been exceptional "for what it is". PT6766 CEA will do it and with a bit of change and a bit more lag, Forced Performance GT3794HTA is not a Precision turbo but I reckon from what I've seen makes me think they have a compressor map more suited to RBs (and 2JZs) - a little wider flow in the 30-40psi boost range (the Precisions definitely need more boost to make these power levels), and they sound awesome. A SLIGHT (ie 100 or so rpm) bit more lag than the two Precision turbos though.
Going on a roller (dyno dynamics) tomorrow... Ewwww :(
I'll try and get a run on current tune with same fueling to see roller vs hubber before we play with boost
Awesome :)
+1 actually, I've been treating the difference between these two as ~11% (so 600hp @ hubs = 534whp/399rwkw) so will be interesting to see how close this is.
There used to be a fairly well proven 7-8% difference between the hub dyno and a roller, we could repeat it every time.
The hub dyno we use has now been updated with new software and corrections (the 600hp run was done with this) and they are meant to read similar now.
Ahh cool, good to know - I had partly based that number off what SAU people insisted when comparing hub dynos and otherwise but have been starting to get suspicious after seeing trap speeds of cars run on DD being much closer to cars with similar Dynapack numbers (ie, my own) but had used that partly because of avoiding angsty Aussies complaining about inflated numbers :)
Keen to hear the results anyway, especially when you nudge the boost up!
Well that was a bit of a fail, there is an issue with the dyno and even with 4wd set to 50/50 torque split the thing was doing burnouts as soon as it came on boost...
Ended up going 560hp but started spinning at 550hp and pretty much flat lined from there. Would have been well over 600awhp on 24psi if it had traction :)
Edited by SimonR32
put 20 fat kids in the back! dont comment until we have results!!! :P
this is still with the 6262 yeah simon?
No access to 20 fat kids so it'll have to do. The power was almost ramping vertically when it started spinning and then hovered around 550awhp from 5500-8500.
Yeah 6262 T4 divided 0.8 rear
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
