I was thinking about getting a Precision PT6262 for my RB26/30, have had a look on eBay $1137.28 delivered and Powertune Australia looks to have dropped their prices to$1150, only $13 difference so i ordered through Powertune Australia as they have warranty for the turbos as well as the support! I am excited and can't wait to test this baby out!! :)
sounds about right, powertune quoted me for 6266 jb $1080
Finally got my 6466 .82 twin scroll running on a RB25/30 - beautiful response down low and its well on boost by 4000 rpm if not earlier,
Currently making 308rwkw at 13psi - low boost as the engine is still being run in.
That's good to hear! What's the maximum psi you plan on running on pump gas with that 6466?
Also, can you please do me a personal favor and measure the exterior diameter/width of your housings? I'm just worried I may not be able to fit it in my engine bay as my current setup is already a tight fit. Here's what my engine bay looks like:
wow 86 pages now? this thread is popular!.
got some results from my build for yaz.
431 hp atw @ 16psi on the little 6262 t4 t/s .84 on pump with plenty more left in it. will update the dyno charts section with my dyno sheet when I can be f*kt, or after I go back for the second tune.
Well, curiosity got the better of me after I encountered an issue with my 6466. I removed the unit, removed the drain and inlet oil restrict or and had a peek inside. Seems the entire rotating assembly is shifting forwards and backwards inside of the cartridge housing, almost as is there is a retaining clip missing. So on the blower I get, and it seems they don't really seem too keen on warranting it as I removed the restrictor. The fcuk? I wasn't born yesterday! I'll. upload a vid of it soon. I hope precision comes to the party on this one, same goes for PT.
I'm still debating whether to go with 6262, 6266 or 6466 as I'm planning to run this on 98 octane pump gas no more. I was told by a vendor the spool difference between a 6266 and a 6466 is almost negligible.
Yeah I can measure it up for you PM me to remind me if I forget!
I had the same dilemma I spoke to precision directly and workshops in the US that dealt with them and they all pretty much said about 300-500rpm difference in each so I bit the bullet and went the bigger as I knew id always be curious if I didnt. I haven't looked back put it that way, although I have it in twin scroll on a 6 boost manifold to help it all along and its on a 3L
Should be mid 20s on pump and 30+psi on E85 for the get farrked boost setting
  • Like 1
the 6466 is much bigger than a 3540 .7 front if that helps
Thanks for your feedback Donut_king! It looks like I'll be going with a 6266. The 6466 seems like it would require a lot of boost to come alive and that is no fun mated when it comes to pump gas.
Edited by G37Sam
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
