I was thinking about getting a Precision PT6262 for my RB26/30, have had a look on eBay $1137.28 delivered and Powertune Australia looks to have dropped their prices to$1150, only $13 difference so i ordered through Powertune Australia as they have warranty for the turbos as well as the support! I am excited and can't wait to test this baby out!! :)
sounds about right, powertune quoted me for 6266 jb $1080
Finally got my 6466 .82 twin scroll running on a RB25/30 - beautiful response down low and its well on boost by 4000 rpm if not earlier,
Currently making 308rwkw at 13psi - low boost as the engine is still being run in.
That's good to hear! What's the maximum psi you plan on running on pump gas with that 6466?
Also, can you please do me a personal favor and measure the exterior diameter/width of your housings? I'm just worried I may not be able to fit it in my engine bay as my current setup is already a tight fit. Here's what my engine bay looks like:
wow 86 pages now? this thread is popular!.
got some results from my build for yaz.
431 hp atw @ 16psi on the little 6262 t4 t/s .84 on pump with plenty more left in it. will update the dyno charts section with my dyno sheet when I can be f*kt, or after I go back for the second tune.
Well, curiosity got the better of me after I encountered an issue with my 6466. I removed the unit, removed the drain and inlet oil restrict or and had a peek inside. Seems the entire rotating assembly is shifting forwards and backwards inside of the cartridge housing, almost as is there is a retaining clip missing. So on the blower I get, and it seems they don't really seem too keen on warranting it as I removed the restrictor. The fcuk? I wasn't born yesterday! I'll. upload a vid of it soon. I hope precision comes to the party on this one, same goes for PT.
I'm still debating whether to go with 6262, 6266 or 6466 as I'm planning to run this on 98 octane pump gas no more. I was told by a vendor the spool difference between a 6266 and a 6466 is almost negligible.
Yeah I can measure it up for you PM me to remind me if I forget!
I had the same dilemma I spoke to precision directly and workshops in the US that dealt with them and they all pretty much said about 300-500rpm difference in each so I bit the bullet and went the bigger as I knew id always be curious if I didnt. I haven't looked back put it that way, although I have it in twin scroll on a 6 boost manifold to help it all along and its on a 3L
Should be mid 20s on pump and 30+psi on E85 for the get farrked boost setting
  • Like 1
the 6466 is much bigger than a 3540 .7 front if that helps
Thanks for your feedback Donut_king! It looks like I'll be going with a 6266. The 6466 seems like it would require a lot of boost to come alive and that is no fun mated when it comes to pump gas.
Edited by G37Sam
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
