Detonation on pump fuel would also depend on cam/headwork too. As larger duration camshafts would lower dynamic compression. You may find some cars that have been built very well may make a lot of power and only gain a rather small amount(in comparison to others) when switching to E85/C16. Your limiting factors would be the small exhaust housing/pump fuel/standard manifold.
Standard mani-mick o has made 340rwkw on e85 stock mani low mounted, mafia did 320rwkw low mount 3076 0.63a/r, theres been others in this power range with stock mani so I would tend to think its not as limiting as the pump fuel n housing
Yep Mafia had wmi, check out the new manifold thread- scottynm35 said someone just made 430rwkw throught a stock mani on an RB- hes a pretty respected fellow here and theres no reason to doubt his claims.
I was limited to 16psi and 278kw's on 98 with the GTX and 0.82rear, gained 42kw with E85 and the road suddenly became an ice skating ring,
Edited by AngryRB
Same here - Tuned by Jez, SR20 GTX3071 0.82 limited by knock on 287kw/18psi on 98 pootral.
Unfortunately its E85 if I want to go more.
Anyone tracking a car that close to the knock threshold on petrol needs to get ready for a new tractor engine imo. Considering I made nearly 60kw more on the same turbo with an auto, and was nowhere near the knock limit...
"Unfortunately?" what have you got against e85 anyway?
"Unfortunately" the stuff is in poor supply in NSW.
I kind of like being able to fill up when I need to, rather than have a car only capable of blasting around my own block and needing a trailer and jerry cans to go to wakefield (3 hours drive out of Sydney, where most of us live).
That attitude is probably why there are no pumps getting installed. :P
Ha. Troll.
You made 60kw more on what kind of boost? 26/28 pound wasn't it?
Jez knows I flog the car, and thus it is tuned accordingly.Wouldn't have lasted 2 full wakefield days if it was on the limit. I know its hard to remember a time before E85 for you, but people still did track cars back then :P
  • Like 1
A lot of people wanting to see a 6466 on an RB26 dyno sheet... I will post this pic and vid but keep in mind it's not finished yet. The 6466 turbo is pretty awesome. We did an overlay of this turbo compared to the old setup (twin GT28-10's) and the car makes heaps more torque and power in the mid range compared to the twins.
583kw on 30psi
Precision 6466 with 0.84 rear
6 boost mani with 50mm turbosmart gate
280degree 10.8 Tomei cams, bigger valves, springs, retainers, porting etc
E98 Ethanol from Powerplus
Tuned by Trent @ Chequered Tuning (0414 944 146)
Still running off wastegate spring pressure (no boost controller), hits 23psi at 4500rpm. Needs a larger gate because it starts to creep up slowly towards 30psi (hence the increasing torque curve). Holds 30psi after about 7000rpm til redline so we can probably run more boost after the ignition is upgraded (blows out spark above 30psi). Definitely more left in it.
  • Like 1
583kw on 30psi
That is a fantastic result! Very nice, thanks for sharing!
  • Like 1
Cool. what rear housing are you running on the 25/30 and are you retaining VCT?
Very impressive results! Here is a progress picture of my 6466 mounted on my 30/25 motor. Motor was getting put back in today and I got a quick snap
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
