Detonation on pump fuel would also depend on cam/headwork too. As larger duration camshafts would lower dynamic compression. You may find some cars that have been built very well may make a lot of power and only gain a rather small amount(in comparison to others) when switching to E85/C16. Your limiting factors would be the small exhaust housing/pump fuel/standard manifold.
Standard mani-mick o has made 340rwkw on e85 stock mani low mounted, mafia did 320rwkw low mount 3076 0.63a/r, theres been others in this power range with stock mani so I would tend to think its not as limiting as the pump fuel n housing
Yep Mafia had wmi, check out the new manifold thread- scottynm35 said someone just made 430rwkw throught a stock mani on an RB- hes a pretty respected fellow here and theres no reason to doubt his claims.
I was limited to 16psi and 278kw's on 98 with the GTX and 0.82rear, gained 42kw with E85 and the road suddenly became an ice skating ring,
Edited by AngryRB
Same here - Tuned by Jez, SR20 GTX3071 0.82 limited by knock on 287kw/18psi on 98 pootral.
Unfortunately its E85 if I want to go more.
Anyone tracking a car that close to the knock threshold on petrol needs to get ready for a new tractor engine imo. Considering I made nearly 60kw more on the same turbo with an auto, and was nowhere near the knock limit...
"Unfortunately?" what have you got against e85 anyway?
"Unfortunately" the stuff is in poor supply in NSW.
I kind of like being able to fill up when I need to, rather than have a car only capable of blasting around my own block and needing a trailer and jerry cans to go to wakefield (3 hours drive out of Sydney, where most of us live).
That attitude is probably why there are no pumps getting installed. :P
Ha. Troll.
You made 60kw more on what kind of boost? 26/28 pound wasn't it?
Jez knows I flog the car, and thus it is tuned accordingly.Wouldn't have lasted 2 full wakefield days if it was on the limit. I know its hard to remember a time before E85 for you, but people still did track cars back then :P
  • Like 1
A lot of people wanting to see a 6466 on an RB26 dyno sheet... I will post this pic and vid but keep in mind it's not finished yet. The 6466 turbo is pretty awesome. We did an overlay of this turbo compared to the old setup (twin GT28-10's) and the car makes heaps more torque and power in the mid range compared to the twins.
583kw on 30psi
Precision 6466 with 0.84 rear
6 boost mani with 50mm turbosmart gate
280degree 10.8 Tomei cams, bigger valves, springs, retainers, porting etc
E98 Ethanol from Powerplus
Tuned by Trent @ Chequered Tuning (0414 944 146)
Still running off wastegate spring pressure (no boost controller), hits 23psi at 4500rpm. Needs a larger gate because it starts to creep up slowly towards 30psi (hence the increasing torque curve). Holds 30psi after about 7000rpm til redline so we can probably run more boost after the ignition is upgraded (blows out spark above 30psi). Definitely more left in it.
  • Like 1
583kw on 30psi
That is a fantastic result! Very nice, thanks for sharing!
  • Like 1
Cool. what rear housing are you running on the 25/30 and are you retaining VCT?
Very impressive results! Here is a progress picture of my 6466 mounted on my 30/25 motor. Motor was getting put back in today and I got a quick snap
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
