unfortunately not. Yavuz and my girlfriend went through the previous dyno runs so i am not exactly sure why they couldnt find something that was comparable. It was also becoming quite time consuming as we have used Unigroup for years and there are loads of runs that have been done on their dyno over that time so we kind of gave up on looking
It does drive a lot different and i am sure the drag strip will tell me its a different car.
Standard head studs and we dont want to lift the head. We are only using E-Flex without an ethanol sensor so had to leave some room for safety, and its only a street car ;)
I know many will say stock head studs should be fine but honestly, 485rwkw in an S14 is way more than enough for now. It leaves us some more power for when we get bored ;)
Edited by ido09s
Jez posted up on FB an update on his gtr yesterday. Stock motor, so studs and HG stock, and he lifted the head at 435 or so rwkw.
Oh, that's with a 6262
I couldn't imagine a 485kw S14....!
That is just silly :)
We went with the 6766 as the response is pretty much the same as the 6466 and it has the ability to make a bit more power. Its also made more power at lower boost which is always a good thing. Comparing it to the T78 we had on it its quite a bit more power for the same boost levels.
The plan isnt to stay that way trust me.
Next step is to get some head studs, an ethanol sensor and get it all sorted. Will put more boost in it and see where it goes. It ran 137mph on ET Street with about 420rwkw so see what it does with the new setup ;)
  • 1 month later...
Nice!
Precision are also about to release a few more of their new Gen2 CEA range - probably one of the more interesting to 'streetable' people fiends on here would be the PT6870, which is apparently rated to just over 1000hp. Will be interesting to see how that goes when results start filtering through.
Nice!
hmmm interesting will be definetely waiting for those.
Some of you may already know we temporarily made the jump to an 8285 on the SR and took it out with a no mercy attitude. It was going to either go mega fast or turn into a grenade. It chose the later option! Sprayed the track and in the process the tyres. We were on 58psi and all I can say is when it came on from 2nd gear wow....never felt anything like it.
Another close call with a wall, but in Flying 500 style managed to save it. Bottom end is carnage!! Glad I didn't wrap the car, I have plenty of SR spares.
http://www.youtube.com/watch?v=xACxbx6C6R8
And the incar...
http://www.youtube.com/watch?v=OivcTogApps&feature=youtu.be
Something spectacular was going to happen and you delivered :)
Im just glad you didnt scratch the roof!
Looking at the incar, oil pressure light at the top of second, engine rattled 3rd and BOOM 4th :(
wow is all i can say!!!!
Thats one hell of a save given there was no chute involved
Just curious PJ, is it just me or my lack of knowledge when it comes to cars as quick as yours, but does the engine bog down quite a lot on launch with your car? What 60 footers does it run?
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
