From what I remember, 6266 .84 divided rear with stock head forged bottom end, stock compression 26psi @ 135km/h (dunno what rpm)
T517z 10cm stock head and bottom end 23psi @ 150km/h (big HPI 3" dumps/ custom twin 3" to 3.5" front pipes/ custom 3.5" catback)
Both on caltex Eflex
Going back 25th of this month now with greddy camshafts and id2000's to see what happens, gonna work the cam gears for maximum response and midrange
Jez over laid his old setup with n1 turbos and his current 6262 and they both came on pretty much the same...could be posted in the 400kw thread
On the street my 6266 feels very nice, very happy with it
How early man? It's a lot of turbo to have breathing that heavy, that early, on a 2.6. I can't picture your result here and now but I know its impressive. Remind me when it's making that sort of boost (1 bar).
1 bar on 3rd gear at 3750rpm with stock nur spec rb26 engine...
  • Like 1
  • 1 month later...
The only turbo of the range relevant to most people here that I am aware of is the 62mm CEA wheels - they are funnily enough the same OD, but seem like they may be a bit "deeper" (ie, distance from inducer diameter to exducer diameter along the shaft - not from centre). There seems to be a negligible amount more lag, and about 5% more flow at higher boost.
That car rules, so much. It makes me very very happy - reminds me of old HPI videos of HKS street meets :)
Thats low 8s trap speeds, on radials - in a road legal car. Happy thoughts, indeed.
Thats what i was asking about i'm gathering that applies to the 6266
The 6262 and the 6266 got some changes
The 6266 now claiming 800hp
What was changed on the 6262 same thing or?
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
