have many people had much success with the 6266 turbo on a built 2.6?
coming from my old supra with a stock 3L (no cams etc either) with a 6466, the 6266 on my gtr feels considerably laggier.
It does seem to be the journal bearing (purchased the car with it on) which would certainly effect the transient speeds between shifts but I still thought there would be more lower in the mid range.
I've just completed a full service and its off for a retune this week so ill have a dyno sheet to put up soon
Interested in seeing 5862 as well. I have a 2.75L BC stroker build on stock bores (N1 block) and I want something super responsive for pumpgas on the street. I'm not one for E85 or racegas because they aren't really available in the area.
I'm betting my stroker, with Poncams A, ported head, +0.5mm SS valves, etc will run pretty dang good with the 58mm turbo.
Finally got my car tuned.@19 psi, 93 octane 611/449 tq on precision 6262. Lmk what u guys think
EC990DBB-75E3-4453-89C1-EC9B0C5E4339_zps
This pretty much has me convinced of the 6262. Are you on a stock stroke and/or displacement?
I have a BC stroker motor on new N1 block (std bores), ported head, SS valves, Tomei Poncams A, etc. I'm going for a nice response build.
Another shop is trying to get me to run their billet (not precision) version of the 6262 and I may take them up on it since he's offering a great price and warranty. He just wants to see what it will make on a good RB26 setup. They have made 640 whp on a stock 2JZ with their 6262 and wanted to see what it would do on a built 2.75L RB26.
What manifold is everyone running?? I don't want to have to change my R32 PS or A/C out to later.
Hey guys,
Just picked up a Precision 5858 off a mate that needs a rebuild. It currently has a .63 rear housing and I was curious if anyone has seen any results with this kind of set up on a RB25.
I've seen Rondofj's results with slightly smaller 5558/.63 combo and his car made 286kw with full boost around 3600-3800rpm. So I'm assuming I'd have no issues running a 5858 with the same rear housing ... might make the magical 300kw mark too? (kinda all I want on a unopened RB25 for drift anyway).
My guess is it would be responsive as f**k, just wondering if it'll choke in the top end, and/or cause excess exhaust heat/restrictions etc.
Thanks!
Edit: I saw the 5858 on the RB25 neo on the last page too, very impressive!
1998 R34 GTT
Stock RB25DET NEO
3" metal intake
Z32 afm
Precision 5558 0.63a/r turbo- ported cover
Turbosmart Compgate 40mm off turbine housing
Cooling Pro FMIC
Stock exhaust + intake manifolds
3" dump with plumb back
100 cell metal cat
3" exhaust
Siemens Deka 60lb injectors
Walbro GS3442 fuel pump, direct voltage
Nistune
Yellow Jacket coils
286rwkw @18psi, intake temps getting hot, will change piping and crank boost up later, and post dyno sheet when I have access to a computer
Edited by Run-It-Hard
I saw that last night
Should go awesome, same HP rating as a 6266 with less lag !
Less lag will be a stretch, just because the wheela are smaller doesn't negate the fact it's pushing 50hp more of air. Keen to see results though, could be a downgrade/upgrade for me
Wound the 6262 up a bit more for racewars this weekend
Effing-A that is some good power!!! All this on a STOCK bottom?!?!
As a mechanical engineer I LOVE reading data and sorting through turbo selection and compressor maps...none of which Precision provide...but DAMN the numbers don't lie!!! I guess they let their powerbands do the talking. This turbo would be sick on my stroker motor.
I have to ask, why do so many people keep the revs down on their dynos? Am I crazy in thinking mine will go 8-8500 no problem?
Edited by HarrisRacing
You'll notice it pretty much makes peak power at 5-5500rpm.....no point revving it to 8k.
Green line is power. Power peaks all the way near 7500. Even if the power stays over 600 above this, there is still a reason to stretch the powerband out and have the tune in place for the revs. I am curious if the engines can do it is all...maybe this is too much to ask for the stock bottom end?
So it is.
A built engine will rev beyond 10k if you want it to...i.e. Massive turbo.
Limiter is at 8800, kicks in around 8500... I'll change around 8500 on the weekend.
I think the dyno was just set to limit at 8000
Edited by SimonR32
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
