  • Replies 44
excellent, how does one get involved with helping out? dont mind being involved in oganising one if it means getting on track sooner.
There's one in the works, Stu - an official SAU one. Once the details are locked in, they'll be posted up! Meant to be in mid-June, assuming all goes to plan.
Go down there (seeing as you're a bit closer than most of us), kick some asses and ask for more days to be made available to us on weekends, maybe? :(
I dunno honestly, but that will be our first obstacle. With OP gone, it's already hard to get track time, and will become increasingly so as time goes on, unfortunately. :blink: Duncan did get a date from them AFAIK, so it's just a matter of us sorting the details, and that will be happening soon.
Stu, to get involved you need to hand over your keys to anyone who has that little blue bar under their name with the word Executive in it. Once you've done that, it's simply a matter of a nudie run down George St, and you're in.
yeah things are obviously 50% harder now OP is gone.
SAU NSW has booked Wakefield back in November 09 for the only unbooked weekend date in 2010 - 18th June. We are also on the waiting list for any other weekend dates. As always we will run it as a driver training day to help our first time trackers get out there and give it a go :thumbsup: Eastern Creek is not realistic to hire at $10k ($300 for 33 cars) to break even on a week day.
For those who have already done a few track days I would recommend Circuit Club days, SSSC days or just open wakie days. And post up in here and get a few other people along :cool: Also Noel (Fineline), one of our favourite cockroaches is down at Wakie in April so head along then
Personally at this stage the june date is my target to have the race car back on the track running well
If you need a hand, lemme know... I can scrape knuckles like the best of em! :thumbsup: Or is this one at the mechs again?
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
