  • Replies 114
Paint the floor is like the other guys said is the first thing I would do. Easy to sweep up dust and oil spill plus it lights the place up a huge amount. We painted the work floor in some generic paint and 3 years later it hasn't bubbled or scratched though. It had had a fair bit of oil on it to before painting. Also paint the walls white. It refects the light off the walls so you don't get the shadows when working in the engine bay or inside. I have one single car shed with 2 fluros and a double car with 2 fluros. The double has painted walls and is brigher than the single car garage.
I haven't done it yet but have been thinking about getting some free standing secondhand food prep benchs off ebay. Pretty sure the sell for around $150 each. Full stainless steel frame and top. Some come with sinks also.
If your staying there for a while mount a few random power points and plumbed in air line with a few outlets, one on the bench and one near where you work on the car and one near the door. Works great with the coil air lines. Saves having a hose and compressor your alway tripping over. Only would cost prob $150 to do.
If somebody knows where to get cheap pallet racking let me know.
some great discussions but pictures speak a thousand words, love the tyre racks but how have you built your benches. Do you have storage sections and what about backing boards.
2 hours into cleaning, still a shit fight. I just don't have enough storage space. The track car normally lives where i'm standing, street car on the back slab.
On the plus side, when it's clean i have a nice open well lit area for working on stuff.
haha ,nice post.
hre is the workshop i have at the moment with a friend (mooving out in a few months to my own, friends need to convert it back to wood workshop for his buisness. but still will have around 150m2 to do my stuff in the new place, see how that one turns out)
paint i used , was a pretty cheap one, payed about 500$aus for around 350m2 (all peeeeling of right now), couldnt afford the good epoxi stuff back then (and didnt not want to spend that much on a property that was not mine :( )
pics of workshop when it started:
The workshop:
Chassi room:
Paint room:
Engine room:
my engine out :ermm:
my 2 ugglys:
engine in bits:
Tyre racks:
My car in the chassi room:
the built this:
some froends coming to visit:
hope i can make a cleaner and tidier workshop in the next place i go :rant:
keep pics coming dudes, need ideas :(
hahahahah, thanks guys :rofl2:
there is a fridge hehe, but no beers :D (i drank them all heheh)
will post a few pics of new place in a few weeks :P, at least this one has tile floor, so no need to paint hahahah, yuhuuuuuuuu.
pmr-33, yes its under the owneds house, the one keeping the place..........
Who needs a house when your garage/workshop is that big...
you need a house to store all the shit that doesn't belong in the workshop.. Ladders, paints, camping stuff, seasonal stuff... That's all gotta go somewhere, so you need a house
Finally got some of mine. Not that elaborate and certainly not going to get anyone exicted. But it is very functional for everything I use it for. The last pic is of a mobile bench I made up to have a portable access to my main tools.
Future possibles. Behind the brickwall (behind the punch bag) is just shelving and the Hot water unit. I am considering knocking that wall out and putting in more shelving and a tirerack and moving the hot water unit outside to get it out of the shed.
Please provide any thoughts/ suggestions/ critisizims as I really want to make it bigger and better.
Nice one!
Would love a hoist, but I don't have the roof height.
I work on my car while it's parked on my trailer a fair bit. It's good as it makes the car a nice height to work on. I can jack it up on the trailer also.
But nothing beats a hoist.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
