  • 1 month later...
  • Replies 105
Hi Guys, sorry for the delay on the reply.
After multiple attempts to get the nav conversion going i've been offered a refund by the supplier/installer who just can't seem to quite get the thing going so i'm going back to the video out option from my samsung mobile which works nicely anyway. Gives both video and audio directions from the factory screen and speakers system but obviously no touchscreen on the headunit. If anyone wants to see the phone approach just let me know and i'll get some photos uploaded.
Thanks
Thanks
Id love to see it. Wish this worked with the iphone
Hi Scarf
There is an interesting thread presently running that uses an IPhone 4
see:
Video In Motion Solution, Cheapskate - DIY Job for those with iPhones
Its for a V35 - but I wonder if it could work on a V36 with the av input plugs and the V36 JDM TV??
Peter Melb.
Hi Scarf
see:
Peter Melb.
Ive just downloaded those apps, and I'll give it a go tonight. Cheers
  • 1 month later...
nope.
4 figure sum though and I won't elaborate on which side either.
that is just unfortunate
is there a solution to get at least the tv working? i can survive on my phone gps like i have in the past, just not the holistic solution for a new car that i would've liked, oh well.
thanks
without money - not really.
that car is unique to japan and as such the systems are as well. to get it working outside that country is a full refit and that also counts for the TV side of things.
that could work if th car was sitting still.
the thing people are not getting with this car is the complexity of it. you can't simply bang a box into it. it all has to be linked in properly.
OK I have a victim :P
red 370 SP with a touch screen. WA customer.
stay tuned for a rework of it. I'm probably going to dump the HD as well.
anyone keen for a fiddle.
processor is a hitach SH4.
OK:
this is a NON NAVI car I am working on. now the unit that is in it IS IDENTICAL to the local 370Z unit. plugs,wiring,screen - everything!
for those that want a easy way out of the radio and lack of navi issues - 370Z/G37 panel IS THE WAY TO DO IT!
firmware would stop it. already been down this path with 3 toyota units. it will load it speak in english but not load the maps or anything else.
the only reason I mentioned the non navi car is that it uses a jap variant of the 370z item and whilst looking at the USDM and local 370 z manuals its the same unit electrically.
the navi version of the V36 is ENTIRELY different.
Chris,
Could you list which version is possible to convert or are you still playing with car from WA? What functionality it would get? Also what is your estimates in $$?
I take non-navi doesn't have any cameras and dash buttons layout is different so can identify easily?
Thanks.
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
    • You sir, big win tonight. Precision never supplied compressor maps in the past and Idk when they started, but it seems they only offer for a few of the older gen2's which is exactly what I have. I punched in some numbers and seem to have gone with the wrong turbo. 600-700whp isn't in the most efficient area and is close to the choke line. 800whp is well off the map. Punching the numbers into a 68mm gen2 turbo map is bang on in the center. Here I was thinking going smaller would shift the power band down, but in reality it would just make it so much worst due to my rev limit. I would have never thought.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
