For a road car yeah bushes with adjustment is the way to go. For a track car adjustable arms are better more adjustment and rose joints for more rigidity. On a street driven car adjustable bushes will give you enough camber adjustment and will last longer (on the roads) than rose joints/Hiems that are used on adjustable arms
Just bought the $1299 set (whatever series they are) for a V sedan. Didn't want the cheap ones and didn't want the external reservoir ones because I thought that would be to much for a daily sedan.
Getting over the ride height, body roll and the gap between my tyre and wheel arch
  • 4 weeks later...
  • 2 months later...
camber adjust isnt possible with the skylines so it seem pointless to get the ER but what about the fact that they're monotube design coilovers and that they quoted" allow the end user to individually adjust and set compression and rebound damping rates.". not to sure what that is any help.Some sites also mention that these can also be used for street and track im not sure how true that is does anyone have any feedback as I need to replace my leaking stock suspension before registering it.
been using ER's right now on street for about a month - i like a firm ride, and i havent found it too stiff - to be honest seems to be a nicer ride than tein monoflex's i used on street
very very happy with them.
That makes it harder I'm thinking of going BR then use the rest of the money to buy a EDFC kit to control the settings whilst driving handy as a track tool.The ER have some little extras worth having aswell.what do you guys think
the EDFC from tein wont fit BC's coilovers unless you can modify it etc. im sure someone has..
I have extenders for my rear coilovers so I can adjust them in the cabin manually.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
