A how-to would be awesome.
I'm in the process of getting my tiptronic going, and either a Works Bell shifter, or get some CNC'd up and make my own.
if your getting some CNC'd i might be interested. not interested in the carbon look.
but anodised .. hmmm
  • Replies 73
Will talk to the GF's brother, he's an engineer.
And then i'll see what my magical auto sparky can do, he's a wonder with electronics, especially auto shifters.
Maybe find a way around the delay when triggering a "manual" shift?:whistling:
please elaborate dale?
i just meant if he's having a look, and he's clever; he might find a fix for the delay when you shift manually, a la Scotty and your's ECU wire snip...
wanna know a quick way to shift(which you may already know)
when in Manual. and you change gear, as soon as your push the stick to change, pull your foot off the accelerator and stomp on it again..
also the shift kit install is helping us shift quicker.
ill get in the car tomorrow morning and tell you which wire it is and what size resistor.. u really wont need a switch, i dont think ive ever touched mine..
Yeah, knew the "Rolling the throttle" one, and I'm trying to justify a shift kit to the "Minister for War & Finance" at the moment...
do what i do.. pretend somethings wrong with it and then say it needs to be "fixed" lol
the guy who did mine n jethros said if you send the valve body to me he'll do it for under $500
I remember you said who it was, but do you want to give me a number, or a link to contact him?:cheers:
I'm very keen to do this mod as well......
If somebody (Scott or Aaron) could do a post which summarized "why" and "how to" that would be brilliant.
Would also help those searching in the future!
Thanks guys!
ok so i slacked off.. ill do it today lol.. ill take some pics as well
Oh and a little birdy told me yesterday the the error when you get it limits boost to .7PSI for those of you running the standard boost system.
Edited by Jetwreck
  • 4 months later...
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
