iv got a pair of rb25s for 110 for the pair
pm me if your keen
Where you at Perth? Yeh I wanna give these ago first before i use the nismos.. If theres nothing wrong with these why not settle for the cheaper one... Still genuine NISSAN... Quality stuff.
And if you're intent on pulling the motor apart RB30 will work out much cheaper than any stroker kit.
Yeh that is true... And would give more displacement then the 2.7L... Nice thanx haha... Forgot abt that one.
using rb25 afms is a cheap way out and not really that effective..
32 gtr running a single gt3582r maxed out the afm voltage at 20psi boost, that means they read 100% air flow either tho the turbo was still sucking in more. you cant put a HP or KW rating on them as such because you can keep tuning the ecu at 100% afm reading it just becomes a very basic tune.
if you use z32 afm's then they will accurately read past 20psi.
personaly I would use a MAP sensored ecu instead even if you run twin turbos
if you go normal power fc and hold your power around 330kws you should be able to get away with standard afms
but if you wanna up your power later you will need to upgrade your afms either nismos or z32 afms
nismos = $800-900 most tuners i spoke to prefer tunning with these
z32 afms =$400-500 for the pair
taken all that in to consideration maybe your better off buying a djetro to start with to save a bit of coin if your planning on upping your power in the future.
or many other ecu options vipec, link, wolf ect..
have a chat to your tuner
AD4M So what your pretty much saying is @ above 20psi the rb25AFM's are useless? If this is true yes i need z32's. So is the above true for price wise as ive search the rated power for both z32 comes out with more HP capability. Nismo is more $$ because its "NISMO"?? I don't have a mental amount of stashed money in my backyard or anywhere for that matter as some people do lol. Cause I do plan on getting alot of "reliability" mods to go with just a tad later after the turbos so i don't blow the thing up.
we recenty put some 2860-5's on a bog stock 32gtr. 298kw @ 19psi. very drivable. comes on nicley from 3ish and buy just over 4k it all on hard.
Nice, so would you say that is safe for daily? and is around 20psi safe for the internals? Plan on internals sooner then later if it isn't ><. haha making me drool for these 2860's =D~
Edited by Specrzx
what do you think happens when a map sensor reads 20psi and continues until redline? the same thing, the horiztonal load axis never changes
thats in an ideal world 100% right
but if the boost pressure spikes, you can have the different part of the map it will go into tuned for less timing and more fuel as a safety
if your afm's are maxed out they will always read the same axis.
There must have been something wrong, as rb25 AFM's max out at about 220rwkw each, airflow is airflow so 2 will max at around 440rwkw, how was the scaling on the PFC setup, as i cant see them hitting 5.1v on a 3582 @ 20psi even if its a 1.06 housing.
Kinda off topic, but..Hey OP was that you in the white 34 GTR heading towards the freeway on Kent St around 1:30-2 PM today? (Thurs) D:
I was in the white GTT going in the opposite direction :P
Nah man not me ><... Working at that time haha.. And not my location im in NOR.
Anywawys i figured i'd settle for the D-J price wise for PFC and AFM's Turns out to be the same as PFC D-J with all necessary parts. Kinda stupid to not go to it isn't? Nengun getting the new ones with EL hand controllers cheap. AFMs So $$..
  • 3 years later...
I know it is not a new model but what do you think of the Greddy T78 Single Turbo, I have it in my R34 and was wondering if twin is better. There are many different oppinions and I was wondering why they would take a twin system off if they are better?
if you are in Perth, WA
take your car to Josh @ Galvsport in Osborne park, he currently has 10+ big dollar GTR builds of all the combinations above and is a very well respected engine builder. he will take the time to find out what you want, what you will do with it and make a suggestion from there.
he is currently building my HKS 2.8 and has been great to deal with.
Thanks but in NSW
Does not look like there are any oppinions about the Greddy T78 as to what is best , the original Twin system or the T78, guess I will keep looking.
As I am a new forum user even though I have been a member for a while and I have been told to search before putting a new post up, it seems to upset some older grumpier members, but it gets bloody frustrating when you cannot find the info you would like as I am not the best on computers. :unsure:
I was put in about 5 years ago, just had it tuned with a new HKS EVC 5 boost controller and it goes well , already lovin it. Might do a couple of other things first and see how I feel after that.
Thanks
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
