  • Replies 340
Hey man. $5 for the RB26DETT. PM me if you are interested. Free postage would sweeten the deal considerably.
Anyways seriously, when I was young about 4 years ago I ploughed my dads car through a fence tryin to get some sideways action. Noone could imagine the shame of having to knock on that persons door saying ur the one who did it. Never since that day have I tried anymore wreckless drifting or tryin to get sideways. It just too easy for something to go wrong. Some people learn the hard way, and some even harder, but unfortunatly, thats the way it is...
Gluck with everything.
the previous car i had before was a 355 xcop vt commodore.. rid that off.
now its this r33 and i hope my r32 wont be ridden off ...
the reason why there was all wires near the boost gauge ( as you can see it was a gauge lieng around) was becasue my wires were getting fixed about 10 minutes before the accident. ill have full spec details on the car (images) .
i have had ylwgtr2 to come over and have a look with his professional assitance i now have plans on what im doing to get this beast back on the streets
thanks for all the flaming and i appreciate the people wishing me luck next time.
Cheers
You are a complete and utter tool mate, I am glad that you are ok, and no one was hurt or police were not involved.
I can't afford a GTR, and you go and write one off? plus this is the second? I hope the first one wasn't a GTR aswell.
From now on you should be banished from owning a nissan period! stick to Holdens, no matter how many you wreck, they will keep pumping them out of the factory until people stop buying them
Age 20 and good experience in driving.
Sorry buddy, but unless you do as much milage as a taxi driver there is NO way you could have enough km's under your wheels to be an experienced driver.
Dennis, you're a menace. And the roads will be a little bit safer until you are mobile again. Hopefully a little older and wiser and a lot lower powered. Something like a Datto 1200 would be good methinks.
Damn.. Having alot of Km's under their belt --> experienced? Taxi drivers are one of the worst drivers out there!
Also.. doesn't Melb have a law which states P platers aren't allowed to drive High Performance cars [especially with turbos]?
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
