Was an 'oh crap' moment, skipped a beat!! Lucky it was still hanging on the balancer. True Paul, you lost one too!
It's ready to go, just have to wait till Tuesday for tune booked in. I'm curious too, it's just linear on 14psi, I just want it to go well, butt dyno is the one I actually care about. Numbers are just that, numbers...
Meh, nah spent too much already!
Spat a power steering belt mid corner today on Putty Rd, scary moment!! Nearly crashed :( Needed to be retensioned anyways. Damn they are hard to steer with no power steering!!
what balancer are you using?
Ross balancer with powersteering under drive pulley.
Brand new belts stretch and need to be re-tensioned in my case....didn't retension soon enough.
Time will tell if it's something more commonly wrong or not. I've read the balancer thread.
Don't notice it. My knees don't bend the other way:)
Only if you put you feet right up to the base of the seat.
If it's a problem, I usually mount them on the passenger side.
Link to extinguisher bracket topic :Dhttp://www.skylinesaustralia.com/forums/topic/376435-cams-approved-fire-extinguisher-bracket/page__st__40__p__6621367#entry6621367
I see you're booked in tomorrow for a tune Sean!
Yeah if Yavus can get away from your car for just a few hours!!! :P
I also put in the crank trigger kit this arvo woot!!! It works fine, it's all coming together :D
mines going on the dyno in about 5 minutes. Just putting the airbox back on :D
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
