Was an 'oh crap' moment, skipped a beat!! Lucky it was still hanging on the balancer. True Paul, you lost one too!
It's ready to go, just have to wait till Tuesday for tune booked in. I'm curious too, it's just linear on 14psi, I just want it to go well, butt dyno is the one I actually care about. Numbers are just that, numbers...
Meh, nah spent too much already!
Spat a power steering belt mid corner today on Putty Rd, scary moment!! Nearly crashed :( Needed to be retensioned anyways. Damn they are hard to steer with no power steering!!
what balancer are you using?
Ross balancer with powersteering under drive pulley.
Brand new belts stretch and need to be re-tensioned in my case....didn't retension soon enough.
Time will tell if it's something more commonly wrong or not. I've read the balancer thread.
Don't notice it. My knees don't bend the other way:)
Only if you put you feet right up to the base of the seat.
If it's a problem, I usually mount them on the passenger side.
Link to extinguisher bracket topic :Dhttp://www.skylinesaustralia.com/forums/topic/376435-cams-approved-fire-extinguisher-bracket/page__st__40__p__6621367#entry6621367
I see you're booked in tomorrow for a tune Sean!
Yeah if Yavus can get away from your car for just a few hours!!! :P
I also put in the crank trigger kit this arvo woot!!! It works fine, it's all coming together :D
mines going on the dyno in about 5 minutes. Just putting the airbox back on :D
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
