Hi fellas :sick: ,
Well after a journey lasting nearly 5 years from bog standard road car to current guise, delighted to say that the "old girl" did us proud last weekend here in the UK at Santa Pod at the FIA Main Event.
She finally decided it was the right time not to break or give us any grief & we finally saw sub 7.5's - running a 7.45 @ 187 & then afterwards a 7.49 @ 183 to back it up. Was an absolutely amazing feeling & fair to say has been at times a hard slog.
Huge thanks to Abbey Motorsport here in the UK who look after all tuning & engine work + the crew - all over the moon.
Here's a few vids & a couple of piccies
7.45 run (we were against an 8.4 rail with a 0.9 headstart)
The car still has a bit more to give & we will keep on "tweaking away " but just brilliant progress from the team & i'm over the moon for the guys who at times have bust a gut to get the car together
cheers
John
Edited by R33draggtst
https://www.sau.com.au/forums/topic/323617-project-gtst-745-187-mph-backed-up/
  • 3 weeks later...
Hi fellas :P ,
cheers
John
What engine is in it?
sounds like an eight?
Specs from there website :D
1997 R33 GTST Nissan skyline
Engine
Nissan Skyline RB26 N1 Engine - bored to 2.8L
HKS Step 2 Pistons
HKS Billet Crank
HKS Forged Rods
AET prototype turbo
Motec M800 ECU
HKS Fuel rail
HKS Manifold/wastegate
Moran Motorsports fuel injectors
HKS Ignition Amplifier
ACL Bearings
JUN Camshafts
JUN Head & Block studs
Gizzmo MSIBC Boost Controller
Abbey Motorsport Head Gasket
Veilside Plenum & Throttle body
Chargecooler System
Abbey Motorsport Prepared Head
Porting/Polishing Abbey Motorsport
Magnafuel Fuel System
ATL Fuel cell
Moroso Dry sump System
One off Abbey Motorsport exhaust system
Chassis & Running Gear
Webster race Engineering fully licenced 25.1E legal cage
Jerico 5 speed gearbox with airshifter
Ace Clutch
Trick Titanium bellhousing
Mark William propshaft
Strange fully adjustable F & R suspension
Strange discs & calipers
ARRC rear axle
American Racing Wheels
Stroud parachute
Interior
Motec Datalogging System
Racepak Display
TRS Harnesses
Reverie carbon fibre seat
OMP Fire System
Exterior
Carbon fibre front splitter - http://www.carboncerbie.com/
Carbon fibre Doors
Carbon fibre boot lid
GRP Front + rear bumpers
GRP Headlight vent
ARRC Rear soiler arrangement
Lexan F & R screens
Lexan windows allround
What breakages have you had ? (I know there is probably a list).
Just gives an insight to what happens when you want to achieve the top tier of drag racing for us commoners to understand lol .
I take it you are stripping the motor after every meet to check everything is alright.
John is running about the same power as I do running 7.2s. (1300-1400hp)
Our motor went untouched for just on 3 years and I'm sure John gets a huge amount of runs/meetings from his motor as well, stripping a motor after every meeting sounds like something the old school V8 boys might do :-)
Rob
  • 4 weeks later...
Hi guys :( - hope you are all well.
To be honest we have reasonably decent reliability considering the power output.
We don't bother taking the engine out every meeting unless it's one of the 2 big ones each year (Main Event & European Finals) as they are both 4 day meetings & you can be looking at 12 runs + at each one.
Normally it's a case of finishing the meet & if all looks & feels ok then a compression test at the end & if all good she gets packed away & then left really until the next meet. Prior to each meet we get the car out a few days before, detailed check over & put her on the dyno just to check basic settings & if all ok off to the meet we go.
Only hassle we have had over recent times has been a couple of gaskets failing which is no huge surprise, so off with the head & get it changed at track if needs be & then back out again :-)
Same crank for the last 3 years, same pistons for last 12 months, same rods last 12 months etc, same block etc - normally change bearings regularly & exhaust valves etc just to be on the safe side.
These RB's are tough buggers :-)
  • 2 months later...
Hi,
I'm new guy here in this forum and I like the forums too...
Well, I'm working on Killer project hear in Bahrain... I have a RB30 block and 26RB head
I need some one to put me on track... any suggestion for picking the parts
My goal to run in 7.5ET
Nice work John
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
