  • Replies 227
Damn, look at all those 50's!
The long wang really kills it for us NA boys. I actually thought I went quite quick through the LW this time around (at least on the run I didn't spin out), but still ended up way down the bottom. I've got to make up the points on the skid pan, and as Gerald has shown we Supra's aren't complete boats out there!
It's interesting going back over past DECA results to see where you're improving. My LW seems to be getting slower, is that because clockwise is a slower track? MW seems to be getting progressively quicker! Down from an original 33 seconds to mid 29's. Probably explains why I'm loving it more and more too.
I think next time I'll tackle the cones on the wangs a bit faster, I'm sure there's plenty more grip in the car.
after scrutinising the results i had a decent amount of top 20 results but i got let down by a couple of slowest times (damn that cone i took for a ride)
all in all very pleased with it :)
I'll have to try it, I've never been good with the whole heel and toe action.
Come past one day I'll teach ya :P
Once accomplished Kez, aim to double clutch heel toe which will not only stop the jerky downshift, but will save your synchros a lot. This involves what Hamish described but you let the clutch out in neutral as you blip, then clutch back in before selecting the lower gear.
Yep that's where it's at, you get into such a habit that you end up doing it without thinking about it. I reckon it's easier to learn double clutching and then progress to heel and toe so you have an understanding of the rev matching concept.
I learnt just doing it while I was driving around town.
I.e. RoundABout's etc
start by learning to blip the throttle without worrying about the brakes
you will quickly learn how much you need to press it to get the revs matched
then you can learn to do it with your heel (or you can also roll your foot like I do with my size 14's)
Yer roundabouts are the best for it. I learnt the heel toe action in an automatic of all cars lol, just in neutral to practice the amount of pressure needed.
warning. you may send your passenger through the windscreen the first couple of times :P
LOL
Booooo not happy with results. Did worse than last time lol. Big improvement on the wangs but sucked a big one on the skidpan, complete reverse of how it normally is for me...go figure. Congrats to the winrars.
well done to the winners!
dane- blistering pace in your road car!
some cracking times amongst the field aswell, which shows quite a few people capable of knocking on the top of the table...
perhaps we should look at banning rear engine cars? :P
some great pictures from various people as always.
best fun i've had in my car to date!
IMHO unless running in a field of all cars of the same class and power levels, then just focus on improving your own times compared to own results.
Granted, with the DECA points scoring system it is a bit difficult to gauge how you went, since it's all placing and not time based. In that case use the seat of pants gauge or setup an in-car camera so you can measure your own times :P
What is your vehicle setup like if you don't mind me asking? Power/suspension mods?
Agreed, I try to gauge myself against similar cars :P
Have you tried clicking the tabs on the bottom of the worksheet? You can switch to the worksheets that show your times...
Greg - How were some of your results??! If you hadn't have buggered a few up you'd be right up the top mate, awesome job. 4th in the first Long Wang run is awesome. The old girl still has life in her yet :P
the old "if you didn't bugger up"
if only... but that's what deca is all about and it's great fun.
i was wrapped with some of the times considering the guy driving........ but a few little concentration lapse's is all it takes to throw a good time out the door, and as soon as you do slice some cones or wd there is always someone eagerly celebrating on the inside! :P
birds: car is fairly mild, and still used as daily commuter, 200kw and some jdm tein super streets, it has a few basic suspension arms too, but nothing over the top.
I need more grip!!!!
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
