  • Replies 227
Damn, look at all those 50's!
The long wang really kills it for us NA boys. I actually thought I went quite quick through the LW this time around (at least on the run I didn't spin out), but still ended up way down the bottom. I've got to make up the points on the skid pan, and as Gerald has shown we Supra's aren't complete boats out there!
It's interesting going back over past DECA results to see where you're improving. My LW seems to be getting slower, is that because clockwise is a slower track? MW seems to be getting progressively quicker! Down from an original 33 seconds to mid 29's. Probably explains why I'm loving it more and more too.
I think next time I'll tackle the cones on the wangs a bit faster, I'm sure there's plenty more grip in the car.
after scrutinising the results i had a decent amount of top 20 results but i got let down by a couple of slowest times (damn that cone i took for a ride)
all in all very pleased with it :)
I'll have to try it, I've never been good with the whole heel and toe action.
Come past one day I'll teach ya :P
Once accomplished Kez, aim to double clutch heel toe which will not only stop the jerky downshift, but will save your synchros a lot. This involves what Hamish described but you let the clutch out in neutral as you blip, then clutch back in before selecting the lower gear.
Yep that's where it's at, you get into such a habit that you end up doing it without thinking about it. I reckon it's easier to learn double clutching and then progress to heel and toe so you have an understanding of the rev matching concept.
I learnt just doing it while I was driving around town.
I.e. RoundABout's etc
start by learning to blip the throttle without worrying about the brakes
you will quickly learn how much you need to press it to get the revs matched
then you can learn to do it with your heel (or you can also roll your foot like I do with my size 14's)
Yer roundabouts are the best for it. I learnt the heel toe action in an automatic of all cars lol, just in neutral to practice the amount of pressure needed.
warning. you may send your passenger through the windscreen the first couple of times :P
LOL
Booooo not happy with results. Did worse than last time lol. Big improvement on the wangs but sucked a big one on the skidpan, complete reverse of how it normally is for me...go figure. Congrats to the winrars.
well done to the winners!
dane- blistering pace in your road car!
some cracking times amongst the field aswell, which shows quite a few people capable of knocking on the top of the table...
perhaps we should look at banning rear engine cars? :P
some great pictures from various people as always.
best fun i've had in my car to date!
IMHO unless running in a field of all cars of the same class and power levels, then just focus on improving your own times compared to own results.
Granted, with the DECA points scoring system it is a bit difficult to gauge how you went, since it's all placing and not time based. In that case use the seat of pants gauge or setup an in-car camera so you can measure your own times :P
What is your vehicle setup like if you don't mind me asking? Power/suspension mods?
Agreed, I try to gauge myself against similar cars :P
Have you tried clicking the tabs on the bottom of the worksheet? You can switch to the worksheets that show your times...
Greg - How were some of your results??! If you hadn't have buggered a few up you'd be right up the top mate, awesome job. 4th in the first Long Wang run is awesome. The old girl still has life in her yet :P
the old "if you didn't bugger up"
if only... but that's what deca is all about and it's great fun.
i was wrapped with some of the times considering the guy driving........ but a few little concentration lapse's is all it takes to throw a good time out the door, and as soon as you do slice some cones or wd there is always someone eagerly celebrating on the inside! :P
birds: car is fairly mild, and still used as daily commuter, 200kw and some jdm tein super streets, it has a few basic suspension arms too, but nothing over the top.
I need more grip!!!!
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
