  • Replies 160
hay mate
ive had several fast cars and i wouldnt be investing 150,000 into a car if i didnt know how to drive would i
my question was about the cars with equal drivers skill.
marc
ill have some pretty good suspension setup and wide as f**k rims on the back ill be investing heavily on traction and keeping it down as best i can.
mickey thompson drag slicks should be good enough lol.
also throwing the whole nismo suspension arms catalogue at it
You spent $150,000 on your GTT? Holy shit :domokun:
also by faster do you mean
who has a higher trap speed?
or
who wins the drag race?
as you may loose the drag race but have a higher trap speed, so you may be "faster" but still loose
ie a vl turbo with transbreak spooling for 30 second will always loose, but have a mega high trap speed - which may be what you call "faster"
You spent $150,000 on your GTT? Holy shit :wacko:
compensation I would say
compensating for what mate??
just trying to do a lil something different
yeah im close to 150k
heres a basic rundown of the costs
car was 30k
engine is 40k
gearbox is 10k
clutch, diff, tail shaft etc 10k
brakes 6k
suspension 3k
body, kit, paint 10k
rims 7k
2nd set of rims 5k
cage, seats, harnesses 7k
carbon parts 10k
gauages 1.5k
ecu 2.5k
thats 142k
doesnt include other stuff like seam welding half the chassis, the carbon dash that im probs gonna buy, and the stuff that has come out of the car like the 9000 stereo that was in it as my daily.
also my best mate is building it and i help out where i can so im saving heaps on labour as well
not a single piece of the engine or electronics and 95% of the carbon was second hand
and a lot of it is custom stuff
my mate has a stanza with a sr20 putting out decent power (runs c16 and a big turbo at 30psi). revs to 9000rpm (launches at 6800rpm). he said that the hardest thing to do is try and change out of first gear without it bashing on the limiter for ages. it revs up so fast that you don't have time to gather it up off the line and then grab the next gear before it is banging on the limiter
Can't help but laugh at the number of people putting their money on the GTR. They're quick, undoubtedly, but really. Check how many AWD cars are below 10 seconds in Australia, heck in the world. Now check for under 10s RWD. You'll be going for years sorting through how many RWD cars there are. They've been developing RWD drag cars for a lot longer, AWD is still playing catch up in this field. And can I ask, if you can put all your power through two wheels without spin, why do you need the front wheels working too? AWD was developed for when you couldn't do that.
In short, my money's on the GTT.
also the gtt can run mega small front tyres and save friction, not sure if its worth much.
this thread is insane!!! those power figures are just out of this world haha
btw ~150k spent on the car? i think i just won't mod mine lol :'(
yes but do a search on how many 10 second gtr's there are and how many 10 second rwd skylines there are.
You guys know the fastest street legal/manual Supras in the world would run with some of the fastest Pro drag GTRs in the world? If the RWD car has good suspension setup, driver, tyres etc then RWD starts becoming a bonus where an AWD car becomes a liability. We aren't talking <400wkw street tyred cars where most of the answers run a lot more true...
I just won't bet tbh. The R34 has imho by far more potential, but it will be substantially harder to get to said potential. A T04Z R33 GTR will be a 10s, a GT42R GTt SHOULD be in the single digits if everything is done right.
unless the GTT has a good suspension setup id put my money on the GTR winning as you are going to have traction issues in 1st and 2nd possibly even 3rd gear in which time the GTR will just walk away from you. both cars starting at 100km/h would be a different story though.
Possibly! Possibly have traction issues?!
With 700hp and RWD I'd be surprised if he's not still wheel spinning across the finish line.
The 4WD will win simply for the fact it can get the power to the ground. 4WD will be enough to overcome the HP and weight disadvantage.
As for the posts stating "too many variables", how about a bit of conjecture? Of course it's impossible to know definitively who would win until the race is done, but lets just put on our "what if" hats for a second and debate who would and who wouldn't.
or
I'm gunna bet he means first across the line.
After all, that's all that matters.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
