Found this an interesting read, and since buying my car recently I have read a lot of people have had problems using Shell V Power in there cars..
I have been Running BP Ultimate with no problems so far..
http://www.treehugger.com/files/2010/06/bp...-gulf-spill.php
98 octane should be 98 octane, no matter who is selling it. Most refinaries are shared anyway...
I normally run 98 octane from absolutely anyone without any problems (eg put in mobil 98 after draining the tank, then filled with caltex 98 for the blue mountains cruise). I firmly beleive if your tune is high strung enough to notice variation in 98 rated petrol it is too aggressive.
This is the worst case scenario for BP...it's an environmental issue...and BP have struggled to fix it. This is a PR nightmare for them. Even if they get the leak rectified ASAP, it'll throw everything upside down.
I also believe other Oil companies will seriously reconsider the use of their off shore oil rigs. It can go one of 2 ways..they can do their best to upgrade the security of them to show they will prevent something like this happening. Or cut their losses of the potential another PR nightmare and stop using them.
If thats the case, I might start using Shell, at least that way I can save 4 cents a Ltr...
mate i run nothing but vpower in my r33, don't know if its placebo or not but i get better fuel economy from good old'e vpower rather than ultimate!
my dad works at the shell oil refinery in sydney where they produce the stuff.shell in nsw supplies bp and bp supplies shell in queensland as they dont have their own refineries in each state.
BP however do put some extra additives in their fuel that they get from shell in nsw that magicically clean your engine and make your car like a race car LOL.
but with shell, mobil, bp they are pretty much the same in terms of performance and economy id say vortex is just as good but has been known to have some bad batches of fuel hope this helps
Never had issues with Caltex 98. In fact it's all I run.
Personally I used to find Shell had a placebo of more grunt, but less economy (Which after reading, was found to be because Shell runs more cleaning agents then Caltex, hence less fuel to burn)
Caltex gave better economy then Shell, but ever so slightly less top end punch (Placebo again) but the car sounded like it idled smoother.
BP I've only ever run once as I got the worlds worst batch of fuel that caused it to kick and buck and belch flames.
Personally, I swap between Caltex and Shell without a second thought, I mainly stick to Caltex as it's cheaper for me.
just another tip never fill up at the the servo when the tanker truck is there you will get the last of the fuel at the bottom which has all the crap
and keep your receipts had some shell fuel years back at a little independent servo which was full of water and fudged my motor had receipt got the fuel tested and took it to court and won.
Yeah thats been so much help, I have had a few people tell me about bad batches from Shell, but at the end of the day it could happen to any petrol station. Just means I won't have to worry about finding a BP when I need fuel....
:P
So let me get this straight.... millions of lites of oil have spilled into the ocean creating what is probably one of the largest man made environmental disaster ever in history, thousands of dead wildlife and fish, thousands of americans now ruined and/or without a livelyhood and all you can think of is how will you be able to cope with having to use Shell V power now?
yes.
what is your point?
All of which will not affect him in any way, shape or form. The o ly affect to him clearly is the fuel. There's nothing wrong with opening a thread and asking for advice.
Yep, bit of an embarrassing thread...
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
