A while ago someone posted up Teng Tools 14mm sump plug removal socket. Went into Supercheap on Sunday and they are selling a full kit of every sump plug socket you could ever need made from chrome vandium steel in a metal box for $30. The brand is Protool.
PS: the Teng one is on backorder, they have run out of stock. S
Again? The were out of stock when it was being discussed before (so around 23rd Sept), but mine got delivered in pretty quick time anyway. Maybe a week, two weeks tops.
Teng on backorder roughly two weeks wait atm. I already ordered before finding excellent set in Supercheap.
*drools.
The Bursons rep dropped passed the workshop the other day and convinced us to grab one of these. Apparently fully rebuildable and rated to 600Nm. Its good for getting into those tight spots. For a couple hundered dollars, you can't go wrong.
*drools.
enough clearance for rb crank bolts?
Hmm I can't comment on RB's specifically, but the majority of work its done, has been on crank pulley bolts. I'd measure it up on mine but I have a 52mm KoyoRad, so I'm not sure that'd qualify. Rad out, I would say yes.
Awesome news. that's good enough for me to purchase on. Thanks.
  • Like 1
  • 3 weeks later...
Perhaps not something that's up everyones ally, but i've found this quite handy. It's a test light that displays voltage on a lcd screen. It shows reverse polarity with bright led's, red for positive and green for negative/earth. The lcd is crisp and easy to read. There's plently of length too. The only drawback is that it inly does 12v. So I still have to use my older style test light when working on trucks etc. Although not everyone would require this.
Posted Image
Posted Image
Posted Image
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
