As long as you are ok, thats the main thing. Was this around 7.30 this morning? I normally get on Sunbury road near the airport, but it was packed, so I went around
it happened at around 8.30 this morning.
wow..thats very sad to hear man..atleast everyone is ok. whats the speed limit on that road?
speed limit is 100km/h which is the speed that i was hit at because there was no time for me or her to react it happened way to fast, couple guys said that my car spun a few times but i dont recall any of that.
  • Replies 50
Posted Images
lucky she wasn't in that charade then, she would of got crumpled in half.
Maybe the crash is karma for you're immature sig. Obviously you don't know anyone who lived thru WW2.
lol, nice try at being a troll. obviously i didnt write it, its just a comment from another post referring to something else.
nice try though, congrats on sounding like a very mature person :bunny:
From the pic seems like your air bags didn't go off because your windscreen is still intact, the damage seems to be quite big you did not have any aftermarket steering wheel did you? even so the passenger side should still pop :bunny: good thing you and the girl are okay and sorry to see your car is a write off.
From the pic seems like your air bags didn't go off because your windscreen is still intact, the damage seems to be quite big you did not have any aftermarket steering wheel did you? even so the passenger side should still pop :D good thing you and the girl are okay and sorry to see your car is a write off.
thats what alot of people said, im not sure why they didnt go off, my car is 100% legit, nothing dodgy done. i thought maybe because i was hit from the side and thats why they didnt go off.
Pretty nasty accident man, good to hear you're okay and that crumple zone did its job. Airbags usually take a decent impact to go off but they aren't always reliable after many years, and sometimes if the car has had previous accidents people get stitch jobs done on the split panels...
On the bright side you got a GTR coming your way :D
And Mean_R34 get off it...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
