i love those nismo vents for the front bar. must be rare too
ya a lot of people commented on that before...must be...havnt seen on any other car yet...i am not sure...thats how i got it from japan...the guy there must have either put it on or had in his options when he bought the car....
series 3 front bar, with the nismo oil cooler vent thingy which is a option
thought so..i was going through all the other pics to find yours and cass's so see if you guys being series 3 have it or not...lol..didnt..so had to be an option or an aftermarket thing the guy in japan put on the car....
started here.
re-spray, performance, smashed and fixed it x3, restored it, dumped it and got bored of NA power.
where she is now. half way through full cams race specs (cage etc) and undergoing a twin turbo swap.
would be nice to see some more of these cars on cruises........
mine included :yes:
My family has a transport company with semis, that turbo is as big or bigger than the turbos running on our 14litre cummins and detroit engines.
if you've got them posted somewhere to a site like imageshack or photobucket, then just find the link to the actual images (ends in .jpg) and copypaste the links into a post here between image tags
eg: img without any spaces
otherwise hit "add reply" at the bottom of the page, and in the window you see, there will be an upload button below where you type. hit browse, find the pics on your comp, hit upload, and then insert them into your post
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
