Friend of mine just got a tirerack order today and he's a bit disappointed that the tyres he's received are 3 years old.
Perhaps that's something that people can ask if they are ordering.
fark, 3 years old is a bit rough. out of interest what model tyre are they? and what size? I would not be happy with anything over 18months old.
  • Replies 47
They're a Kumho V710 I think. I don't know the exact size but they won't be overly big as they're for his Datto 1600.
Worst part was they told him the date on them was 2010 before he bought them. Haven't spoken to him in a few days but when I know how he got on after contacting I'll post up what happened.
The more tyres people buy from the US, the more expensive tyres in Australia will get. You need to support the Australian official importers of the tyres because the more they buy from Japan, the cheaper they can get them for which is why they are cheaper in the US. The more you buy from the US, the cheaper US prices will get in comparison to Australian prices. I really wish stoogebags would stop doing this.
Personally imported tyres would make up a fraction of a percentage of all tyre sales in Australia so I can't see how it makes up much of a difference. Call me a stoogebag if you want but I'm not paying twice the price for the privelidge of buying local.
why should i pay 100% mark up? seriously
i was quote $2500 supplied, fitted and balance for AD08
i pay $1200 landed and $50 for fitting and balance for the same tyres from tirerack
Maybe whichever stoogebag is profiteering in the aussie market could stop doing that?
Even in the same country its ridiculous, I can buy and ship tyres down from QLD and pay for fitting here and STILL have change from what they'd cost locally.
  • 1 year later...
http://www.skylinesaustralia.com/forums/topic/395003-circuit-semi-slicks/
A guy at Phillip Island ran the AO50s on the Saturday at PI and then the Hankooks on the Sunday. He seemed to think the Hankooks were quicker. He did go quicker on the Hankooks on the Sunday but I am not convinced as Troy was from Newcastle and only had limited running and was still getting his head around the track and his car problems over the weekend. Including popping his engine early on Sunday morning
http://www.natsoft.com.au/cgi-bin/results.cgi?13/11/2011.PHIL.Q1
1_25_AHRG___Troy Fraser____Nissan 200SX_1:44.2561*
People do support it but the fact they jack prices up to gain more of a profit is the problem. Why should I pay $650 per tyre here in Australia when I got the same tyres delivered to my door for $1400
If there is money to be saved on getting high quality tyres I will do it instead of what alot of ppl do and skimp on tyres and get the cheap ones
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
