Anyone know of any good guard rolling services out in the Eastern suburbs...preferably Bayswater/Kilsyth area?
I would prefer the kind who can come to you as I would rather it done onsite at my workshop. Price isn't a major issue, I'm more after a job well done.
Cheers in advance.
https://www.sau.com.au/forums/topic/330489-guard-rollers-in-eastern-suburbs/
I trust Hamish with my food, I don't trust him with my guards :D
Anyone have Athid's contact number? I no have facebook :blink:
I've got a guard roller but I'll be damned if I trust myself to do it properly.
EDIT: All good, found it: http://www.skylinesaustralia.com/forums/180athid-m6642.html :)
Thanks all!
oooo can i borrow your gaurd roller.... need to roll the rear gaurds on my gazelle.... infact .... would you like to practice on my gazelle ?
... then you'll be a pro and can do it yourself!!!
on that not, sorry to hijack your thread, but anyone who has a gaurd roller is welcome to practice on my gazelle if they like, i need them done, and i dont care how good the result! i really dont care!
athid is the best man for the job, but as stated is in Vegas for Trent's wedding ATM
I cant do yours as my roller is broken at the moment ;)
dan from ADM will probably come to you and is located in ashburton... pm me if you want his details
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
