  • Replies 176
I seen your thread...your girlfriend puts hours of work into it and you can't spend a few minutes polishing headlight plastic...come on!
Does the thread have pooper shots?
the first time you wrote it i thought you meant to type 'proper' shots, so i directed to the thread... but now i must ask what a pooper shot is, lol..
Well the proper term is "scot-free", derived from ye olde English expression "scotfreo", meaning to be exempt from royal tax. The singular word "scot" is itself derived indirectly from the Nordic word "skot", which was later influenced by the Old French word "escot". All of which referred to local tax paid to a son of rajab and/or ruler. Therefore to be scot-free you are said to be exempt of charges/tax/penalty.
A pooper shot? Sharpie in the pooper shot. Google it my friend, and then please deliver :/
i googled it and came up with this:
is this what you wanted lol.
stupid fcks no nuffin about skylines, got it fixed and was in no way what you provide me as a solution. Maybe you goes need to go fck urself more.... such a useles forums this is, very helpful dream boats in here too.
well that was a headache to read. maybe you should re-read what you typed before posting.
just a tip.
also why spell 'nothing' like 'nuffin' for? all it accomplished was spelling it very wrong and only shrinking the word down by one letter.
have a nice day:
just a tip.
have a nice day:
well i hope that headach turns into a migraine
If this thread is even remotely true than the simple answer is this:
Your cat collapsed, hence the exhaust temp light came on, which in turn built up a f**k load of back pressure in the exhaust at such a high rpm, which made you lose power and your exhaust to glow so red.
Either way this thread is halarious and the fact you argued about doing such a high speed after saying you were doing 6k in 5th is even funnier. I really do hope this thread was a joke.
Edited by PM-R33
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
