DATE: Friday 6th August
MEET: Parkmore Shopping centre, carpark in front of the Kmart tyre and auto.
TIME: 7.30pm @ parkmore
Destination: pizza joint next to dande KFC
these guys make goooood pizza. in my opinion anyway. and for chilli lovers, options include mild, medium, hot (more than most can handle), very hot, and thermonuclear.
BRING YOUR HUNGRY FACES!
booyah
ok people, due to a miscalculation on my part, i wont be coming to this meet. the meet point and destination are below.
MAP
meet next to the hungry jacks/ in front of the Kmart. Leave at 8pm ish. take a right onto Kingsclere and then a left onto cheltenham. keep going until you go under the railway bridge. at this point, go straight down thomas st (ie: dont get in the lanes turning right). straight down thomas street until it ends at clow st. there should be plenty of parking on thomas just b4 this intersection or you can park at the KFC across the road.
the place is called Paradise Pizza i believe.
once again, apologies for not being able to make it.
https://www.sau.com.au/forums/topic/330953-pizza-meet/
  • Replies 67
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
