Hel Stainless Steel Braided Brake Line Group Buy #2!
Hey Guys,
I've got a set of these HEL braided lines for a R32 GTR non brembo brakes.
I bought them through this group buy and had bought some R34 brembo's for my R32 before I had the chance to install them.
So if anyone is after a set of brand newies for a R32 GTR PM me.
$100 incl postage.
I will check to see if they're compatible for any other car?
  • Replies 165
Posted Images
UPDATE
They arrived today however I was out wakeboarding all day so I wasn't able to accept them.
I will pick them up from the depot tomorrow and hopefully have them all sent tomorrow aswell.
Will let you all know once they are sent.
Thanks for being patient guys.
Cheers :)
You could give it a go. The GTT lines use a 90 degree fitting and different mounts, other than that they are the same. Why's that?
so is it 110$ for fronts and rears? if so I'll take a set for a r33 gtst on the next GB and a clutch line if those are being made
  • 1 month later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
