  • Replies 467
Yeah that was my worry . was a rather last second decisions to buy the rims and i was 99% sure i won't win them at the price i bid, however i did! So will most likly swap my street tyres onto the nismo rims and use my advan for track stuff (they are 9.5j +19) and see how that goes.
What guard was fouling the front or rear? (or both)
Risking not sure if that was directed at me or not but my last track car was far from a posser race car lol so i think the gtr will be fine.
Thanks Djr about the turbo info. i am thinking if my goal is speed event series then the gt-ss or garrett similar will be the go, whatever i can find cheapest at the time.
Well I have the -5 Garretts on my 32 R & to be honest I don't have any real issue with lag. Just leave stock cams in it & bolt on some cam gears. If you are only running 400rwhp (like me) then it isn't turbolag that is going to be the issue it is just outright lack of grunt. Jimmah Eames R33 R that won the Collie hillclimb has phone numbers for rwhp as an example. On the tight and twisty SES rounds (like Busso, Jacks hill, Mt Clarence) the Emo's go better than the GT-R's anyway. Steve Jones flogged everyone at Busso in his.
But as long as the motor will punch out of second gear fiddly chicanes it will be fine on the hillclimbs.
The tyres fouled the guards at the rear. You need to roll the lip out of them to stop the side of the tyre getting gouged. The front wont be a problem as you have to run heaps of neg camber to try & make the car push less so the top of a +22 usually ends up well inside the guard lip. If you run alot of castor the tyre can & will scrape the front of the guard liner but that is only plastic & doesn't really hurt anyone/thing.
As for tyres every man & his dog runs SR2 RE55's on GT-R's. Go & see Kerry Wade at Bridgestone in Bentley. Should be about $2k for the four.
hmm
got my hks piping kit few weeks ago, and can tell you not very happy with the quality of the piping kit was hoping it was top level but isn't really :S debating if i should sell up and try the nismo or trust kit. having a feeling that the only quality one will be nismo (but the price tag is a killer)
my issue is not with the kit alignment but surface finish on the inside of the pipe. I am picky and its not 100% perfect but will pretty good
Also i have a feeling the piping kit will not fit with my ARC airbox which is going to be an ass to change (and dont plane too)
I just need to confirm if it will fit or not but like i said im almost 100% sure it wont which means i will have to use the nismo kit
Edited by Kaido_RR
Can confirm that your arc airbox will not fit.. i bought one a while back and ended up selling it.. even with me not running afm's it still didnt fit..
i've forgotten what the inside looks like.. its all in pieces here actually i shall check for you today.
If anyone isnt happy with those pipes for an R32 i could be interested. There are plenty of reasons why i would prefer a rougher internal finish
I agree, super smooth ports and inlet piping are shite for airflow. As the inlet air sticks to the piping / port walls and slows down.
Edit - think of a golf ball vs a pingpong ball, which one goes faster through the air.
yeah me like trust. good kit. fit nice and don't blow off.
don't worry about the rates of your helper springs. all they do is keep the main spring captive under droop. stops them rattling or coming away from the upper mount. as soon as the car is on the ground they are full compressed and just act as a spacer they are usually only rated high enough to hold the main spring up nice and firmly against the upper mount.
I have a thing against the HKS because of the shallow ramps on the hose retainers..... seen more HKS pipework blow off more than any other.
I've never had a blowoff and was running upwards of 2bar. i did however have a blowup... haha
Yeah I've never once had any pipes blow off on my own vehicles (touch wood) because I'm so totally anal about fitting it properly to avoid it, but have seen many many others do it. I just think if fitment of the HKS version is even slightly lax, there'll be a problem.
This is true, on some of the pipes the lip is made up from a bit of welding blob done on the outsides.. i didnt expect this from hks but it does the job.
hmm never through about it like that, maybe there is hope for the kit still :P
my hks kit has lips around the edge of each pipe so, i shouldn't have an issue with blow off, if i end up using it
i think mine might be for sale, as i might try to use the nismo hard piping kit
this photo gives me hope
however nismo doesn't make the hard piping kit for the bnr32.... however i have found a nismo hard piping kit plus i/c piping kit for a bnr32... not im not sure if its worth the gamble to see if it fits or not (nismo hard piping kit is something like 150,000yen or something)
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
