Sooo true. I'm always way off. Last time I tried to guess a girl's age she was 4 years older than I thought! :P
im getting the opposite at the moment, eg. the other day i said to a mate check out her she is hot and he said thats one of my sisters friends and she is 17 caught me by surprise she looked alot older than that.
back to my original question, username?
  • Replies 191
it was worth a shot lol at least she is my age so at least we have something in common.
on another note i think girls need to walk around with there age written on them it would make it alot easier.
Are you for real man?!
:P
Trying to hook up on SAU...
- http://www.facebook.com/hailzswanson
^^ Google is your friend.
169 at the engine
I had a supercharged 200 (1G), did 110kw at the rear, was the same as the 300's (2J) in a straight line
I see...
BTW "4U2DRM on a IS200 participating in the fully hektik George St cruise"
its a 200 with poor servicing.. would get you 67kw.
:P
Fuck, well that explains it.
:P
just messing around, i dont add people that i dont know on facebook.
hahaha Paul. did not expect to see the username GAS747 on SAU lmao.
Thanks man! its a keeper !
Yeh iv been on SAU for years, we use to have a good laugh on with with my mates ZDENKO and trevor forget what his username is but SAU always had a thing about giving us VL guys a hard time back then. I still read from time to time!
lol u sad sad mo fos... beau if it makes u feel any better i touched that white orion car before she did in the shop! hahahaha
lol man as i was reading i thought u were gna say u touched her or something.... :P
clicked into this thread to see pics of the crappy cars autosalon had... I worked with Hayley, i dont wanna see pics of her....
Now get some car pics up lol
gtfo party pooer.
you soo typed that cos your gf was near by at the time :P:D:P
i just saw paul u signed up 2004.. holy crap lol. thanks again for giving me info to stay at same hotel ^
Here is some pics of my ride.. unfortunatly i didnt get to fully finish it for autosalon but chucked most of it back together gave it a quick detail and put it up on display..
I have noticed a crap load of 4 door R34's now and i wanted to do something different as usual to break away from the common look so i decided to change it completely.
I wasnt sure how it would turn out was a bit worried to see if i could pull it off or not but it came out better way beyond i thought it would look like. I love it.
Although i am pissed off i had my rear wheels sitting flush with guards until i stuffed around with camber arms and stuffed it completely.... fml lol
VLT's had a Skyline engine Haha!
well she's not exactly a showstopper tbqh, nothing personal if you're reading!
and that other asian one, bloody hell, she's hideous!
You like BBW... What you find hideous, we find nice :)
If only you entered your decent looking R33 GTS-T.
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
