You're a hard bunch to please...........
Anyhow,
Small update on progress so far today
Seat rails welded up, with mounting spuds
Went and purchased a new Sparco steering wheel 350mm with a 65mm offset (offset might be too high but can exchange)
A fair bit of dish
Lifeline weld on quick release hub arrived.
Fire extinguisher arrived also
This little bit of kit should be arriving any day now.
  • Replies 137
Posted Images
Could you take a photo of the seat rails from the drivers door? interested to see what happens near the tunnel as far as mounting goes or if they are just welded to the floorpan
You can see that here Jeff;
Fair enough, I think the Pro ADV's must have a bit more cushion in the bottom than some seats. We were nearly touching the roof when we blocked them up to sit where the stock mounts would place them.
The passenger side mounts (Targa one day!) are going to take a fair bit of work with the floor pan the way it is, but I'm sure we'll get there.
Cheers
Smallish update today.
Roll cage is moving along, main hoop diagonal, harness bars, transmission tunnel bar and most of the passengers side door bars are done
Chop chop!, seems this will be the only way to mount the passenger seat.
Some dodgy plumbing of the clutch and brake lines from the master cylinders. Not entirely happy, will probably end up doing them in braided stainless with some banjo fittings over the next month or two. Currently what you can see runs into some bulkhead fittings in the firewall.
Tim, we tried sitting the seat in with the sparco seat brackets and nothing seemed to work. Maybe I'm abnormally tall or something but every option seemed to warrant the need for cutting a hole in the roof so my head wouldn't hit :)
Obviously it's been done many times on this forum, has anyone here mounted a Sparco Pro ADV seat on sparco steel seat brackets before in an R32, if so I would love to know you height, and how you managed it.
Dont stop posting up these pics. I have to go through a lot of this and am appreciating the insights and issues you are having and how you solved them.
I have the same clutch pedal issue you have. I hope the Alloy welding you have done is going to be strong enough seeing the old pedal is a cast part.
My pedal cluster is a TILTON part. I hope the masters work out OK. I gave TILTON all my info in piston numbers, sizes, car weights etc etc for them to work out the master sizes. The cheif engineer at Tilton was very helpful
Edited by Tektrader69
I had to chopthat out too, and weld in a new section in my car to get the front of the passengers seat low enough.
Edited by sav man
What is the advantage of new seat rails as opposed to using the factory mounts ?
Having recently seen a car where a tree impacted just behind the passenger seat, the tree truck pushed up the floor by a substantial amount. Had the tree impacted next to the passenger it wouldn't be hard to imagine that the seat would've been pushed up and the passengers head impacting the roof or cage. This design would no doubt reduce the chance of this happening.
Graham, the clutch pedal is Aluminium with a 3mm wall thickness, fully boxed.
I'd be slightly concerned if we had to modify the brake pedal like this (against regulations here anyhow). But I think the clutch pedal will never see anywhere near the force the brake pedal would. I'm very confident it will be up to the task mate.
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
