Caught person doing 140-160+ in 80 Zone who also went more than double the alcohol limit. The Drink driving ban is canceled out by the speeding ban. Impound, 1100 in fines and no driving for 12 months.
Lucky for him he didn't kill anyone. I'm glad I was doing laser duties when things were quiet and now have him off the road!
He wants to contest it saying his Honda Jazz doesn't go that fast.
https://www.sau.com.au/forums/topic/334931-worst-driver-of-the-week/
  • Replies 167
you boys should be allowed to legally tazer the shit outta them LOL.. maybe this will teach them not to drink and drive.. anyone who repeats drink driving or is double the limit should automatically have the alcohol breathalizer installed to start their cars..
If the speeding fine overrides the alcohol.. Does that mean if he gets off (by chance) that he can't be charged with the alcohol? And LOL as if a Jazz can't go 140...
The speeding doesn't over ride the alcohol as such but when you lose it for 12 months for speeding the 11 month suspension for the alcohol becomes irrelevant. Should be served one after the other not concurrently but what can you do. I guess they don't expect to have people drink driving and speeding to such an extent.
I agree, should also be the same for jail sentences, sick of f**kers being found guilty for 6 or 7 offences but only doing a few months because thats what the longest sentence is, in reallity, if someone knows there going to jail for 12 months why dont they go on a crime spree, there not going to get a longer sentence.
Edited by W0rp3D
i was thinking of mr eps lol
oh some of the posts in here remind me of rants to the Herald Sun. Given that most of you don't know anything regarding the context of the offences (apart from Graeme), perhaps you shouldn't be so quick to condemn?
TBQH I'd rather get done for drink driving than speeding, everyone I know who has gotten done has gotten off a LOT lighter with suspensions / fines, apart from the whole interlock thing.
So...you're saying he probably had a good excuse to be doing 60-80km/h over the speed limit while drunk? Well forgive us for assuming he was a baddie! Obvious devil's advocate troll is obvious.
no trolling brah, i'm just saying that you've been given some facts without context at all, and the usual white knight types give the usual reaction along the lines of "BURN THE WITCH1!!!!!!1!!!!"
if it was a member on here who had been done for an accidental clutch slip / wheelspin / impoundment, you'd all be up in arms, so I'm just pointing out the obvious here :P
if it was a member on here who had been done for an accidental clutch slip / wheelspin / impoundment, you'd all be up in arms, so I'm just pointing out the obvious here :)
speaking of 'obvious', it's quite obvious a little clutch slip does not lead to you being propelled to 60-80km/h over the speed limit nor does it put enough alcohol in your blood to send you over 0.05. Being over the legal blood-alcohol limit and while doing 60-80km/h over the speed limit are not little split second mistakes as your clutch example so the comparison does not work hence people probably would stick up for that person where this is complete disreguard for everyone including the driver themselves.
maybe it was boz in the car.. and he was travelling with one of his gf's.. and he knows that with his gf in the car.. there is no way power to weight ratio can get that Jazz up to 140..
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
