There is something not quite right about the look. its the width or something, can't quite put my hand on it. But I think it looks great.
Question is, spend 15k on that and have a stock motor? Or keep the normal nose and drop 15k into the engine? I think i know what i'd rather... :D
I think it looks good. The rear arches need to have the same styling though(somehow) and needs bigger/ lower side skirts and a rear bar. Other then that, looks great and would be super different, so i would still have it in a flash.
I've tried pricing it all up, Nissan over here wouldn't give out prices for GTR parts.
But I imagine it's not cheap, an M35 bumper is $4,300 + gst here.
Check out Japn yahoo for second hand. Parts are cheaper than R34 gtr's. Easy to get front end bits due to people upgrading to carbon bonnets and fancy front bars.
Front bar approx $200
Bonnet $300-400
Have seen head lights on SAU for $1200-1500 each
My R34 front cost me $4500 in s/hand parts alone.
Reckon you could get it all done for 15k?
I dunno aye... I reckon the headlights will cost around 5K each :)
Considering our headlights are around 2.5K each haha
Thats what the guy says so in the other forum.
"You can pick up an M35 Stagea for around 5k upwards. If you could source second hand parts, which are rare, I reckon that would be around 2-3k So with the car, parts and labour, I reckon you'd be into 10k+"
Of course your talking GBP, not AUD. I guess it comes down to how handy you are with a spanner + Welder eh? 2nd hand parts would be the only way to go. Lets not forget, the guy owns a R35 anyway, so he mustn't be short of coin!
just been on the phone to this guy just thinking of get the back done as i have the impul front to get the back with the R35 tall pipe,s around 700 UK pounds , so thats my next step
hmm.... interesting! Would be interested to see the exhaust he has in there (and how loud it is) and how he got around the ATTESSA pump
wow, way to make your stagea look like a bag of dicks.
front's wider than the rear. the fender and the A pillar doesn't line up properly. the front bumper doesn't line up with the bonnet. man if you're gonna do something unique, do it right.
like wilson tuckey says... do it once, do it right and do it with fibre.
Farken lol. Always good to get a colourful response from you shan. I bet Neil is missing his stag.
Totally agree, doesnt line up at all and needs to to be wider. Some others I have seen look better.
Edited by dirtyRS4
Me too, not sure about the styling issues. Also I'd question why you'd bother, especially in Britain where cars are cheap. For that money you'd get a 2001 Maserati. For just under 20K (pounds) you can just get into a V12 Aston Martin Vantage.... or for less than the 10K take your pick of M3's, Audi Rs's etc.
There's a limit to being different I reckon. I play with my cars but if those sort of cars were that cheap here, I'd be getting one of them rather than a bodged up half breed.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
