  • Replies 41
Posted Images
hey guys so today was a busy day.
I changed the coils over with a mates ones that were working sweet and the problem was still there.
I changed the AFM to another pink sticker one, problem still there.
I decided to take a look at the ECU and to my suprise it has an odd one for it, and remembered that when i brought the engine it was out of an auto car.. and the ECU they gave us came with that engine.. so im guessing the ECU is an auto one.
The numbers are: MEC-R730 B1 6521, Ive done a search but cant find anything about this ecu.
I got a proper r33 rb25det ecu and checked the numbers on it and they are for this car but now it wont idle! its turns over and then dies straight away, if i give it some gas it i can hold the revs myself then if i slowly take my foot of the accel it will sit there idling but will be searching then pretty much die.
I unplugged the AFM and it was the same.. so while it was seaching for idle i got the mrs to plug the AFM back in and it died straight away. Would this mean its the AFM?
ok so today i checked for error codes on the manual rb25det ecu, i got code 12, which is AFM so i replaced it with another one and now it will idle fine and run, but again it is cutting out on boost!! im running out of ideas here!
Can anyone else think of anything to try?
Edited by prawln
I had the same problem when I finished my conversion. It cut out exactly like in your posted videos. I changed the spark plugs, coils, afm and couldn't find anything wrong. So I lowered the boost and took it to a tuner. Got a nistune and havn't had any problems.
ok so have some good news.. got the car fixed and sorted.
The auto ecu was causing the car to not get above 5-5.5k rpm so replaced with a manual ecu and that fixed that problem.
i was still having the cutting out on boost issues though so today i took the pod filter off and put my hand over the AFM quickly to see if i could hear any leaks in the intercooler piping.. and to my surprise bingo herd a hissing sound. I located where the noise was coming from and found that the T bolt clamp was on tere tight but when we put the joiner on the intercooler pipe was in far enough and the T bolt clamp wasnt actully over the piping so was causing it to leak! When looking at it it looked like it was on perfect but apprently not
Took for a run on 5psi actuator and ran mint!! so put the 10psi actuator and also runs mint!!! so problem solved!
Just need to bring the timing back to 15 degrees from 20 degrees as its idleing rough!
Big thanks for everyones help and sorry for this being such a silly minor stupid thing!
  • 5 years later...
Ive got the same f**ken problem its had me stumped for months changed heaps of parts and everything an stull cant get it but i dont think i have an air leak i can easly stall the motor by putting my hand over the afm. has anyone got an answer for this cutting out on boost problem? Its driving me nuts
This post should be in the hall of fame for real!
Stalling the motor by blocking the afm is not an indication of anything. Good or bad.
Alright this is the common problem with basic mods really my only solution is bigger afm and a play around with an ecu. got my hands on a scanner
it's not 1996, buy yourself a proper ECU
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
