Hey,
i've done a search and havent been able to get my question answered.
is there anything wrong with running a cheaper oil cooler, for example the ones around the $400 mark with a oil filter relocator or do i really need to go for a HKS, Greddy or similar style one which costs close or more than $1,000
i just want some honest input about whether people have used the cheaper ones and whether they stand up to the job of cooling the oil out on the track without leaking oil or any other issues?
cheers,
cheers,
Used a just jap one on trackdays in darwin heat with up to 427hP
had no real issues at all once installed helped keep temp down certainly no leaks etc
however
this was an unopened motor with turbos cams an powerfc
so not a big dollar setup at risk
also had to shorten and generally mess about with lines brackets etc to mount
big dollar jap stuff is usually just bolt it up an ya laughing it all fits an works
no messing about with lines brackets an ducting required so if ya need to pay for all that as well
the expensive kit may work out cheaper!?
Alot of the Jap stuff is just re-branded anyway. And a $400 cooler isn't that cheap, if it was only $50 then I'd be worried. Having said that I run a Greddy Oil Cooler, but picked it up 2nd hand for about $400-500
And there I was just about to say don't buy second hand oil coolers.
I wouldn't buy a second hand one unless I KNEW it wasn't from a motor that went bang. You don't want bits of someone elses engine in your oil system.
We did flush the cooler after we bought it, and it did come off a car that was running fine. Like anything 2nd hand, it's worth taking your time making sure it's right before you bolt it on :ninja:
I think the brand of cooler is less important than the fitting location, how much you increase your oil capacity by, the oil used etc.
I run a standard 13row Just Jap core with a Greddy relocator and a BTR thermostat. This is only a very mild power CA S13 so it doesn't generate a ton of heat. It'd probably be too small for a lot of you.
On my first ever day at the track in the car the oil was hovering around 110-115 and it would have been a 25deg day tops. Not ideal giving I wasn't hammering the car - was only a drift day and I was learning very gingerly. I fitted all the above and located the core underneath the drivers headlight and vented the bumper to feed it and vented into the wheel arch so air would flow through properly.
Next time at the track was a 35deg day and it was a proper track day so I was on 100% throttle for much more of the lap, oil temps didn't go past 95deg at the hottest and that was after 10lap stints where tyres/brakes where becoming the issue.
I have no doubt that better brand coolers could do a better job row for row but when you can just buy the next size up in a cheaper core and get the same results and still save monet it's hard to go past.
Space can be an issue of course and in this instance I would opt for a a better core if funds allow. For reference I also run a heavy duty PWR core on my BA for the gearbox to bypass the internal (prone to leaking) internal cooler and make it a bit happier when towing. No issues with either setup.
You can always raise the bonnet at the rear and do some venting/ducting to assist. Both cheap things to do.
Not sure if I'd wanna risk a second hand core though. Not when new cheap ones are..well so cheap :thumbsup:
I've recently bought a Greddy Oil Cooler and Reolcation Kit off the forums second hand. The guy I bought it off got it off Yahoo Japan, so its anyones guess what kind of engine the kit came off. Would it be risky to use the core it came with or should i just throw on a cheap new one to be safe?
I have run Serck (sp?) and Setrab oil cooler cores without problem, I think these are probably just as good if not better than the cores that come in most jap kits. Also just ran rubber hose of the non braided type.
Works out a lot cheaper than buying a HKS or Greddy kit at $900+
Just give it a flush or if you don't feel confident doing this take it to a radiator shop to do it for you.
If you are really worried you can buy an inline oil filter.
Personally I wouldn't put a 'cheap' oil cooler kit on any engine.
It's not really the performance I'm worried about.... as I'm shure they work well enough. It's the reliability I'm worried about.
Poor quality adapter construction, weak threads, poor sealing surfaces, horrible fittings, very cheap hoses and thin cores.... All add up to possible failures.
I don't really want to worry about the life blood of my engine spraying everywhere.... Accident, fire, stuffed engine, mess...
A better comprimise would be to buy a greddy oil cooler adapter, buy some good quality hoses and fittings and a quality core.
My opinion about the problem with the cheap kits is the quality control, leaking at the sandwich plate I think is the most common problem, followed by leaky fittings. I know Just Jap replace these bits no questions asked, but taking the front bumper on and off is a pain in itself.
It's not quality control, it's the build quality and manufacturing materials/methods.... It's all well and good for a retailer to swap out a defective part, but what if that part cost you a motor or worse???
Oil under your tyres is dangerous, oil mist hitting a red hot exhaust manifold is worse...
A cheap oil cooler kit is what 400-500bucks? Plus a thermostat and plumbing... add $200? And you still have poor materials and construction.
Greddy oil cooler adapter with thermostat- $200
Aeroquip lines and fittings- $200
Earls oil cooler core- $150
Tadaaaa.... same money- no cheap shitty parts!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
